What size threads is this??
/ What size threads is this?? #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I am looking at oil filters and found the following in the specs:
M20x1.5mm so the Diameter = 20 mm and pitch is 1.5
Then i see another filter that has
M20x1.5-6H What does the "-6H" stand for??
Brian
/ What size threads is this?? #2
Just a SWAG- but maybe 6 threads high?
/ What size threads is this?? #3
Height of the filter in inches, probably. Was it in a US filter catalog? If so, it would make sense. They would have to list the threads as metric, since that is what the machine has, but they use the more common (to us) inches for height.
/ What size threads is this?? #5
Brian
That's probably tolerance the thread is made with. Here is more information.
I think you are absolutely correct... Thats NOT so say i fully understood what they were saying in the link.. LOL
Growing up oil was oil.. grease was grease... bolt were bolts and nuts were nuts.. Then somebody had to come and complicate matter for everyone with detailed specifications and uses LOL Not that that is a bad thing mind you
thanks again
/ What size threads is this?? #7
thanks again
You are welcome:)
Tolerancing simply describes, how precisely was the part made. Like what is the guaranteed most lose/tight fit.
You are welcome:)
Thanks for the simple definition.. I even re-read the website and still wasnt quite sure what it was.. LOL
Brian
/ What size threads is this?? #9
Same theory applies to your commonly used Unified Thread "fractional or inch" fasteners. There you have class 1,2 &3.
A common 1/4-20 thread is most likely class 2. Now throw in the letter A and B which designates internal or external thread and you'll really be confused :)
http://www.efunda.com/designstandards/screws/screws_intro.cfm
2012 Freightliner Cascadia (A63118)
2012 Freightliner...
Club Car (A62183)
Club Car (A62183)
2024 Blue Diamond Trencher (A63116)
2024 Blue Diamond...
Stone CP13 Asphalt Roller (A64047)
Stone CP13 Asphalt...
Telescopic Boom (A62183)
Telescopic Boom...
Case 580 Super M Backhoe (A64047)
Case 580 Super M...
