What size RM snowblower
/ What size RM snowblower #1
Anonymous Poster
Epic Contributor
I recently traded my B7100 for an L3010, On the B7100 I ran a Woods rearmount SB52 (52 inch width)
It no longer covers the rear tire width on the 3010 (62 inches with the wheel spacers)..
I can get a good trade on the SB52 for either the 60 inch or 74 inch Woods...
Would the 3010 handle the 74 inch ( we get a fair amount of snow in New Hampshire) ...going for 52 to 60 I am afraid will still be a little undersized...
The woods website suggests that even a 25 hp tractor can be used with the 74 inch (they list by tractor HP not PTO) ...
/ What size RM snowblower #2
With a 72" you'll have to slow down in heavy snow. I use a 54" on a 2910 (about the same HP as your 3010) and I can work the tractor pretty hard with a heavy snow. I thnk 72" will work, but you may find yourself going slow when it gets deep.
Peter (fellow New Hampster)
/ What size RM snowblower #3
I'd chime in on getting the bigger one - it's very nice to completely cover your wheel width plus, if possible. I find that my rear-mount does a better job if I get out there as soon as 6"-8" plies up, and again later if there's more. Power isn't always the issue - sometimes the snow just flows into it beter if it isn't too deep. But in any case, the L3010 should handle the 74" unit ok.
A decent rule of thumb is you need about 4 hp per foot of width - notice that most 24" walk-behinds are 8hp. My L345DT (29 pto) handled a 72" rm blower with ease - western Mass snow - similar to NH - but higher taxes.
/ What size RM snowblower #4
If you've got HST you'll be fine with a 74" blower. I've got a 78" on my L3710 and could easily step up another 12 - 18". I've run it through 24"+, no problems. If you have a geared trans, you might spend a lot of time in 1 or 2, when the snow gets deep.
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2017 Ford F-250 4 X 4 Crew Cab Pickup Truck. (A64194)
2017 Ford F-250 4...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
Tow arm attachment (A64194)
Tow arm attachment...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
2018 Bomag BC572 Articulated Refuse Compactor (A64553)
2018 Bomag BC572...
