what size plow
/ what size plow #1
oscer
Central Pa.
JD 4110
Hi fellas, I haven't been on this forum for a good while although it was a big help to me when I was buying my tractor . I have a 2005 4110 with R4s and I fabed up a plow out of an old garden tractor plow. It is slowly being destroyed and I'm starting to think about replacing it. I was wondering what size bottom(s) you guys are pulling with this size tractor. Thanks for any sugestions.
/ what size plow #2
That is a tough call as I don't pull my one-bottom Dearborn plow with my 4300 because it has R4's. Just too wide to run in the furrow for the 14" mouldboard plow. It works great on a tractor with ag tires.
But power-wise, you should be able to pull a 14" one bottom if on the three point. If pull type, then a 12" one bottom because of traction.
And traction just may be a problem with your R4's and a 3ph plow too. ??
/ what size plow
Your right Beenthere the tire definately doesn't want to ride in the furrow.
/ what size plow #4
I am using a brinly 12" plow on my 4110 w/R1 tires. A larger plow would be nice as it feels a bit slow.
The only other issue I have with this plow is the throat clearance is somewhat small since it was originally intended for a garden tractor. I have had some issues with it plugging occasionally.
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
213101 (A64276)
213101 (A64276)
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
