What Size Box Blade?
   / What Size Box Blade? #1
Lutzy48
Miles City, MT
Ford 1710
I have a 26hp Ford 1710. I need to buy a box blade to construct and maintain several hundred feet of gravel driveway. How big of a box blade can I use? I was thinking 5 ft. but would go to 6 ft. if the tractor would handle it.
   / What Size Box Blade? #2
6 foot is a bit much for it. Light work u might b ok But with the rippers down in hard pack or low traction you will struggle.
   / What Size Box Blade? #3
You need a Box Blade a tad wider than your rear tires, so you have enough rooms for the tractor to move forward and back in any shallow trench you create. (building foundation)
If you can pull a Box Blade much wider than your rear tires, you did not buy a heavy enough Box Blade. You need at least one hundred pounds of Box Blade width for every twelve inches of rear tire width. Heavier is better.
Does your Ford have four wheel drive? What tires?
Do you have a loader for front weight?
What is your soil?
LINK: Search Results - Box Blade Size? - TractorByNet.com
PHOTOS: Rollover Box Blade
   / What Size Box Blade? #5
How wide from outside sidewall to outside sidewall at the rear tires?
My L3240 has the rims set 63" wide with R1s and I was able to find a 66" Cammond that works great behind it.
   / What Size Box Blade? #7
If you've got 4wd, ag tires, and enough weight, you should be able to handle 6'. It just won't be as fast. Weight of your tractor is an important variable in this equation.
What is your soil?
To further answer your questions, I do have a FEL with 60" bucket. The soil is sandy clay. Best to do the work in late spring before it gets too hard.
I just measure the wheels and the out to out is right at 60". I think a5'-6" unit would work out well. Just depends on cost.
   / What Size Box Blade? #10
Yes, 66" will be just the right width. Get a HEAVY Box Blade or you will be disappointed.
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
