What Purpose does This Serve?
/ What Purpose does This Serve? #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
I am cleaning up the hood to the 820 and was wondering if the foam on the inside is a critical piece. I know its there for a reason, but should I replace it while im here?
/ What Purpose does This Serve? #2
JD thought it was needed. Looks like it might keep the hood from rubbing the radiator.
I would replace it - can't hurt. Leaving it off might hurt.
Bruce
/ What Purpose does This Serve? #3
Yeah I agree with bcp. Not exactly sure what the purpose is, but they didn't just decide to throw in some foam rubber when they were building. It serves a legitimate purpose.
Thanks. I ran to town and on the way out stopped at an autozone.
/ What Purpose does This Serve? #5
Te foam is supposed to form a seal around the radiator. It makes the fan draw air through the side screens so it is filtered and helps keep debris from clogging radiator fins.
/ What Purpose does This Serve? #6
Ditto what jd110 stated. Foam does similar as fan shroud
/ What Purpose does This Serve? #7
There should also be a block of foam on top of the hydraulic oil cooler, that is to the right of the radiator
(3) New 23X8.5-14 SS tires on 6-lug John Deere compact tractor rims, Coal Valley, IL (A65640)
(3) New 23X8.5-14...
ATS Mini Excavator (A66408)
ATS Mini Excavator...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
CONEX BOX (A65643)
CONEX BOX (A65643)
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
(2) John Deere Row Markers (A64127)
(2) John Deere Row...
