What Purpose does This Serve?
/ What Purpose does This Serve? #1
cartod
Northern, West Virginia
JD 4066, 1023
I am cleaning up the hood to the 820 and was wondering if the foam on the inside is a critical piece. I know its there for a reason, but should I replace it while im here?
/ What Purpose does This Serve? #2
JD thought it was needed. Looks like it might keep the hood from rubbing the radiator.
I would replace it - can't hurt. Leaving it off might hurt.
Bruce
/ What Purpose does This Serve? #3
Yeah I agree with bcp. Not exactly sure what the purpose is, but they didn't just decide to throw in some foam rubber when they were building. It serves a legitimate purpose.
Thanks. I ran to town and on the way out stopped at an autozone.
/ What Purpose does This Serve? #5
Te foam is supposed to form a seal around the radiator. It makes the fan draw air through the side screens so it is filtered and helps keep debris from clogging radiator fins.
/ What Purpose does This Serve? #6
Ditto what jd110 stated. Foam does similar as fan shroud
/ What Purpose does This Serve? #7
There should also be a block of foam on top of the hydraulic oil cooler, that is to the right of the radiator
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
2020 KUBOTA SVL75-2 SKID STEER (A62129)
2020 KUBOTA...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
2008 Toyota Rav4 SUV (A61569)
2008 Toyota Rav4...
110 GALLON SPRAYER TANK (A62130)
110 GALLON SPRAYER...
