What mower for a TN65 ?
/ What mower for a TN65 ? #1
KenPauling
Northcentral PA
Now Holland TN 65D with Cab
I sold my NH1920 and upgraded to a TN65D and need to replace my mower. The KK 6' rotary trail mower worked good on my 1920 but with the TN65 it is too small. I mow about 20 acres of field and don't need a mower to chop down trees. What size and type of mower would be a good choice for field use that wouldn't cost an arm and a leg ? I know there are many types of mowers available but the only type I am familar with is the rotary mower. Are the rotaries the most economical to buy and maintain?
/ What mower for a TN65 ? #2
/ What mower for a TN65 ? #3
You may be able to go to a 10' mower.
I recently was going to purchase a ford 5000 from a local tractor mechanic. they were in the neighborhood of 62 hp as far as I know. I mentioned I wanted a 10' mower and he said it was no problem. I also called the NH dealer and they indicated a 10' would be fine as well.
After looking around alot.. I found 3pt mowers wre less expensive than pull type mowers. I didn't get the ford 5000 but instead got a nh 7610s.. but had little finances left over for a mower.. so i got a howse heavy duty model 10' 3pt mower. It was 2500 taxes and all. The drag model was 800 to 900 more. Next cheapest was a kodiak mower.. again.. 3pt was almost a thou cheaper.
If youhave doubts about the 10' mower.. find an 8' .. but your 65 should be a pretty stout machine.. and like you said.. you'r not mowing trees down.
My 7610s and 10' howse have been great. I can road it down to my pasture a couple miles from my house, mow 10ac, and drive back in just under 3 hours. I mow in 5th gear ( 1st and high ).. works out great.
good luck
Soundguy
/ What mower for a TN65 ? #4
If you mow the entire 20 acres, consider a 10 footer. You won't regret it. I've had good luck with Woods, but it seems most of the popular brands are good. Mowing frequently and keeping the blades sharp, a 3 point rotary cutter can do a pretty good imitation of a finishing mower.
/ What mower for a TN65 ? #5
Drum mower.
Will mow faster than sickle bar mower.
Will have less part problems than the other mowers.
I bought this 5'5" New drum mower for less than $1000.
But it's not so popular in the US unlike Europe.
/ What mower for a TN65 ? #6
Nomad,
Drum mowers are durable & great mowers but this is the wrong application for this customer.
/ What mower for a TN65 ? #7
Ken,
I have a Tn70D which is almost the same tractor.
I currently use a fairly heavy duty bush hog 286. Problem is it is only 6'. This is nothing for one of these TNs even in heavy brush. They can definetly handle much bigger.
I will be upgrading to at least a 10' and have been trying to figure out a way to run a 15' batwing.
After a few cuts you will wish that mower is 20' wide.
Fred
/ What mower for a TN65 ? #8
Hey Ken,
Get a 10 foot pull type. You can mow at 10 mph if you have smooth enough ground and the right gear ratio. Don't bother with a bat wing. I traded my old bat wing on a 10-foot pull type and I'm much better off now. You'll definitely need more hp for a bat wing.
Gabby
/ What mower for a TN65 ? #9
I run a Woods 6' also, the nice thing about the 6' cutter is when cutting around our fences I know I won't hit the post unless I run it over first. Also cutting heavy brush is better with a smaller cutter. But if all I was doing was cutting a field then I would get a 10' pull type cutter.
2008 Mercury Mariner (A62679)
2008 Mercury...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
Generac Speedwash Pressure Washer (A65640)
Generac Speedwash...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
Hyundai Forklift (A65579)
Hyundai Forklift...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
