What liquid expands the most with a temperature change?
   / What liquid expands the most with a temperature change? #21
How about this $12 device plus a solar charger, battery, and 12v solenoid valve?
RioRand 12V DC Digital Cooling/Heating Thermostat Temp Control -50-110 °c Temperature Controller 10A Relay With Waterproof Sensor Probe
Robot Check
   / What liquid expands the most with a temperature change? #22
3/4" Brass Electric Solenoid Valve 12VDC N.C. Air Water Fuel VITON
Robot Check
I can't obtain water from any source other than the frost free hydrant. Besides of course rain. The hydrant has to be turned off or it'll freeze. I suppose it could be insulted and heat tapped but it's still freeze in a power outage.
   / What liquid expands the most with a temperature change? #24
Am I the only one wondering why you have to protect a frost free hydrant from freezing?
Was it not installed correctly?
If the hydrant is open it won't drain.
   / What liquid expands the most with a temperature change? #27
I like MossRoad's 12v idea. I would use a battery with solar charger and rig up a 12v actuator to the handle of the hydrant. That way you still maintain the 'below frost line' drain of the hydrant when the handle is closed.
   / What liquid expands the most with a temperature change? #28
Back in college I had a teacher who had set aviation cable in his greenhouse so when it got warm it pulled on levers to open windows to vent, very simple he said. Calculate the expansion rate of expansion of the cable, put the right length of cable and it's fool proof. It is a simple setup if someone wants to calculate that.
   / What liquid expands the most with a temperature change? #29
Solar & battery with indicator light may be the simplest option.
   / What liquid expands the most with a temperature change? #30
I probably need 10 pounds of push and 3 inches of travel. I don't think the metal could accomplish it.
Actually a small diameter of metal can push a lot more than that. The problem is the 3" of travel. However, you can use leverage to get that, you'll need coefficient of expansion and do the calculations. Put something like a scissors lift together where the cylinder moves a little and the end of the lever moves a lot.
   / What liquid expands the most with a temperature change? #31
I'd ditch the frost-free hydrant, bury the 12v solenoid below the frost line in an upside down 5 gallon bucket, and install an automatic drain valve like they use in a underground sprinkler system between the solenoid and the spigot. Then I'd just install a button on a post on a box with the components I listed earlier.
Or, you could install a 12v linear actuator on the handle of the hydrant. Here's one that says it has 10" of stroke and 330# of force for $10 on ebay.
Linear Heavy Duty Actuator Stroke 15N 33 Pound Max Lift DC 12V Electric Motor | eBay
   / What liquid expands the most with a temperature change? #32
If you do go with solar (or some other electric system), I wonder if you could use something that is spring-loaded to close, so if the power goes out, the water shuts off. (Of course, that might mean a constant electrical drain to hold it open, so maybe that's a bad idea for a solar/battery based system.)
There are mixing valves made which adjust the flow based on temperature. These take no power. I wonder what is driving the mechanical motion in those?
   / What liquid expands the most with a temperature change? #33
Tempering valves use bimetal straps and diaphragms to adjust the temperatures.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
VOLVO A40D OFF ROAD DUMP TRUCK (A60429)
VOLVO A40D OFF...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
