What liquid expands the most with a temperature change?
/ What liquid expands the most with a temperature change? #31
I'd ditch the frost-free hydrant, bury the 12v solenoid below the frost line in an upside down 5 gallon bucket, and install an automatic drain valve like they use in a underground sprinkler system between the solenoid and the spigot. Then I'd just install a button on a post on a box with the components I listed earlier.
Or, you could install a 12v linear actuator on the handle of the hydrant. Here's one that says it has 10" of stroke and 330# of force for $10 on ebay.
Linear Heavy Duty Actuator Stroke 15N 33 Pound Max Lift DC 12V Electric Motor | eBay
/ What liquid expands the most with a temperature change? #32
If you do go with solar (or some other electric system), I wonder if you could use something that is spring-loaded to close, so if the power goes out, the water shuts off. (Of course, that might mean a constant electrical drain to hold it open, so maybe that's a bad idea for a solar/battery based system.)
There are mixing valves made which adjust the flow based on temperature. These take no power. I wonder what is driving the mechanical motion in those?
/ What liquid expands the most with a temperature change? #33
Tempering valves use bimetal straps and diaphragms to adjust the temperatures.
2007 JLG 600S SKYPOWER TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
2007 JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
2007 JLG 1930ES...
2017 INTERNATIONAL LF687 DAYCAB (A60736)
2017 INTERNATIONAL...
2013 GREAT DANE 53X102 T/A REFRIDGERATED TRAILER (A59906)
2013 GREAT DANE...
JOHN DEERE 4440 TRACTOR (A62130)
JOHN DEERE 4440...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
