what length PTO Shaft?
/ what length PTO Shaft? #1
Ronaldjaye
Rocky Mount, NC
John Deere 855
Okay, It's me again with another dumb question! What length should the PTO Shaft be to hook up a John Deere 550 Tiller To a John Deere 855 Tractor...or how do I measure for one? I finally got up nerve enough to make the three point hook-up... Next comes the PTO Shaft...... HELP, HELP, Help!
/ what length PTO Shaft? #3
Be sure to check the input shaft on your tiller. I have a King Kutter tiller, and the input shaft on the gear box is splined, plus it uses a slip clutch. Most likely your JD tiller is set up the same but check it to see. If it is, then I would assume you will need a PTO shaft with a slip clutch as well. I am pretty sure that Tractor Supply has a complete PTO shaft already made up, and it's very likely long enough to fit your set up. In fact, if you get one like that, you may wind up having to cut it down, in which case, you should also watch some of the videos on youtube on how to do that correctly.
This one might work for you:
Weasler Metric Driveline, BYPY 4 Series, 36 in. - For Life Out Here
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2022 EZ-GO ELITE...
7' Quick Attach Snow Push (A66408)
7' Quick Attach...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
