What is too many hours
/ What is too many hours #1
Steuny
Looking to buy a JD 4300 with 430 loader but it has over 1400 hrs on it. Is this too many and am I buying someone else's problems. Granted it would be nice to buy newer but sometimes it isn't in the budget. What ballpark price would be reasonable for a 2001. Thanks
/ What is too many hours #2
Saw an ad for a 2000 with 1297 hours, 420 loader for $13900, if that helps.
/ What is too many hours #3
That is a good number of hours. These machines come in to my shop still running strong with 3000 plus hours on them...however I see machines with 400 hrs and having problems. It really comes down to how it was used and how it was maintained. You may want to call your local dealer and ask them what they know of the tractor or the customer, as far as what kinda work does he do...construction or rental or homeowner and is he maintenance savy. You may also want to consider a 3520 that has the same HP in new tractor. Probably not that much more $$ and comes with warranty and 0% financing. Or if you don't need the 37hp look at the 3203 tractor. This has 32hp but only 800lb lift cap. on the loader...good price tractor...16995 for new one and then there is the 3320 with 300cx loader...same lift cap. as the 430 but with 32hp in a premium tractor, you can expect 20,500 new for that. Anyways...long and short it ultimetaly comes down to the opperator/owner of the tractor and how they serviced/worked it considering the hours are relativetly low. In my area we just had a 4410 with 430 loader mower and box sell for 18000 used in the open market. When talking to the mechanics on a hydrostatic trans you can expect 3000-4000 hours until you have major issues so this tractor has some life left if it has a Hydro trans and not the P. Reverser. If it has P. Reverser.....clutch work could get costly if needed. Expect 1200 to 2000 for a new clutch including labor.
JD DLR
/ What is too many hours #4
There was a 4300 HST on the lot last year for 15,000. I don't know the hours on that one though. I bought mine second hand with FEL, tiller, PHD, York rake, Bush hog for 15,500. No dealer involved. About 170 hours on it. I believe my price was a good deal though. I've seen some on E Bay for fairly low prices as well.
/ What is too many hours #5
Be carefull on the EBay Scam/Deals...I have had several customers in the past 2 years get taken on Ebay with tractor scams. If you can not sit on it or drive it and the price is way to good to be true..then guess what...its to good to be true....
To many scammers out there...watch your money when buying there.
JD DLR
/ What is too many hours #6
My Kubota has 2400 + hours on it. I still consider it as new.:D Other than Battle scars. I expect to put many more hours on it. Dealer says they have one out with 10,000 HR.
I would expect the same from a John Deere.:D
/ What is too many hours #7
You need some history on the tractor before going any further. How was it used, how was it maintained?
good luck!
Scott
/ What is too many hours #8
Hello out there.
I am thinking of buying a 1997 JD 1070. Low hours - under 100. Comes with loader and backhoe (neither used), and roto tiller. Any thoughts on what this rig is selling for these days?
/ What is too many hours #9
FVT55 said:
Hello out there.
3rd identical post, going for a record for duplicates?
/ What is too many hours #10
Engine wise it is just now broken in good. Like has been said by many, it depends a huge amount on how it was taken care of and operated. Almost any piece of equipment can be ragged out in just a short period of time with the wrong operator.
Something else to look at. If you are going to be doing a lot of lawn mowing, find out if it had the front axle changed.
/ What is too many hours #11
I've got a good running and easy starting 5310 with 8,800hrs on it. I don't think 2000hrs is that much either if it looks like they took care of it.
/ What is too many hours #12
We have a few OLD tractors on our farm with 8-9k hours on them. It boils down to how that machine was taken care of. You buy used, you take a gamble on how the previous owner treated it. My best advice is to take someone with you who knows machinery and have them look at it.
/ What is too many hours #13
I was always told that when comparing hours to miles accumulated on a vehicle 1 hour was equal to 50 miles. So most gas engines are good for around 150,000 miles or 3000 hours. factor in the longevity of Diesels which should last 2 to 3 times as long as a gas engine and your looking at about 5000 to 6000 hours before you start seeing the evidence of engine wear. This is all hypothetial of course and depends on how well the tractor was maintined.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
Front Tank Bracket (A64126)
Front Tank Bracket...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
