What is this part and function?
/ What is this part and function? #21
Cruise control on a tractor. That seems weird when the engine is governed anyway, but perhaps with these auto boxes there's no longer a direct relationship between engine RPM and ground speed as one would have with a manual transmission?
/ What is this part and function? #22
Correct for a HST ... Ground speed is mostly set by the forward pedal/CC, but to get maximum speed, you need high engine RPM too ...
  • Good Post
Reactions: bgr
/ What is this part and function? #23
Kubota 3410 HST. I am replacing my rear tires. I took them off to take to tire dealer to have the new ones mounted. While they were off, I cleaned things up a bit and this part (see photo) caught my attention. I could not tell what it did, and the very intentional-looking lever-like device with teeth did not seem to relate to any other part. However, it also seemed bent outward a bit and that may be why I cannot see what it is to connect to or function with. I played around with other functional levers on the deck to see if anything moved there, but none seem to affect this part. I will pick up the new tires in a day or two but before I remount the new tires, I thought I should learn something about this part - given that it may be bent.
Any help will be greatly appreciated. I am prepared to be embarrassed by something I should know but do not. And BTW, I also found a couple of missing bolts on another part that I would not have easily seen with the tires on.
I venture to say it is a parking brake assembly. A very important part of your tractor operation. I might be wrong. Call your dealer and ask to them to review the picture you posted along with model number
/ What is this part and function? #24
That sounds about right. Thanks. Very poor quality parts diagram.
/ What is this part and function? #25
Cruise control is used when working in a large field so you can set it a speed and you can take your foot off the pedal as you do with a manual transmission. I mow 10 acres of pasture along with 4 acres of yard. I'd be a fool if I didn't use the cruise control when practical.
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Toro Mower (A64194)
Toro Mower (A64194)
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
