What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #1
jkgeiger42
John deere 1050 TM1192
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #2
You talking about the freeze plug?
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #3
You need that. It holds the water in.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #4
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #5
Don't run the engine until the freeze plug is replaced and the tractor is refilled with antifreeze. Hopefully, the block is not cracked.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #6
Keyword, ANTIFREEZE. In as much as no one knows your location it might be prudent to use a 50-50 mix of antifreeze and distilled water.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #7
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #8
OP's pics are from an auction....this is the first post from this person? :unsure:
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #9
Shows the freeze plug they are talking about. Let's give the benefit of the doubt.
2011 CATERPILLAR 303.5 D CR EXCAVATOR (A51242)
2011 CATERPILLAR...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
John Deere Bale Spear (A50515)
John Deere Bale...
