What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #1
jkgeiger42
John deere 1050 TM1192
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #2
You talking about the freeze plug?
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #3
You need that. It holds the water in.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #4
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #5
Don't run the engine until the freeze plug is replaced and the tractor is refilled with antifreeze. Hopefully, the block is not cracked.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #6
Keyword, ANTIFREEZE. In as much as no one knows your location it might be prudent to use a 50-50 mix of antifreeze and distilled water.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #7
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #8
OP's pics are from an auction....this is the first post from this person? :unsure:
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #9
Shows the freeze plug they are talking about. Let's give the benefit of the doubt.
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
