What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #1
jkgeiger42
John deere 1050 TM1192
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #2
You talking about the freeze plug?
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #3
You need that. It holds the water in.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #4
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #5
Don't run the engine until the freeze plug is replaced and the tractor is refilled with antifreeze. Hopefully, the block is not cracked.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #6
Keyword, ANTIFREEZE. In as much as no one knows your location it might be prudent to use a 50-50 mix of antifreeze and distilled water.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #7
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #8
OP's pics are from an auction....this is the first post from this person? :unsure:
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #9
Shows the freeze plug they are talking about. Let's give the benefit of the doubt.
2024 WABASH STEP DECK TRAILER (A51222)
2024 WABASH STEP...
CATERPILLAR 299D3 SKID STEER (A51242)
CATERPILLAR 299D3...
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
