What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #1
jkgeiger42
John deere 1050 TM1192
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #2
You talking about the freeze plug?
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #3
You need that. It holds the water in.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #4
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #5
Don't run the engine until the freeze plug is replaced and the tractor is refilled with antifreeze. Hopefully, the block is not cracked.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #6
Keyword, ANTIFREEZE. In as much as no one knows your location it might be prudent to use a 50-50 mix of antifreeze and distilled water.
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #7
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #8
OP's pics are from an auction....this is the first post from this person? :unsure:
   / What is this capped hole right behind the starter? Had it blow out. Kinda stuck could use some knowledge. #9
Shows the freeze plug they are talking about. Let's give the benefit of the doubt.
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2014 ISUZU NPR  BOX TRUCK (A51219)
2014 ISUZU NPR...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
