What is the cheapest kubota zero turn diesel?
   / What is the cheapest kubota zero turn diesel? #51
I never said they rot, the decks are so thin the tension spring pulled through.
I have a 49 year old Sears (Roper) with single cyl. 15 HP Briggs, and the deck is just fine.
Don't use it anymore though, as I have a nice new SCAG with a heavy fabricated deck.
   / What is the cheapest kubota zero turn diesel? #52
never remotely saw that on any deck, even the 800 dollar Walmart special
   / What is the cheapest kubota zero turn diesel? #53
Buying any air cooled gas engine nearing 2000 hours is a gamble I wouldn't take. Far too many are near the end.
Your blanket statement is not true. You ever owned a Kubota gas engined machine? The Kubota engines in Grasshopper mowers are the same block as diesels, just carburated instead of diesel.
   / What is the cheapest kubota zero turn diesel? #54
The key word RickB said is Air cooled, that can substantially shorten the lifespan of a gas engine. The water cooled Kawasaki and Kubota gas engines will have a much longer life span.
Typical life span of an air cooled small gas engine is around 2-2500hrs as a best case most comercial mowers are operated near full load in harsh environments typically and may not see the best maintenence, I think 2000hrs would be a gamble.
   / What is the cheapest kubota zero turn diesel? #55
I said it was a gamble, not an absolute guarantee of failure. And I'm not backing down from my post. If you read slowly you might see I mentioned air cooled gas engines. If you don't agree that's fine.
   / What is the cheapest kubota zero turn diesel? #56
The good Kubota gas engines are also liquid cooled.
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2020 Kenworth T370 T/A 4,500 Gallon Water Truck (A56858)
2020 Kenworth T370...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
PALLET TOTE OF BOTTLES & MISC (A58374)
PALLET TOTE OF...
