What is the cheapest kubota zero turn diesel?
   / What is the cheapest kubota zero turn diesel? #51
I never said they rot, the decks are so thin the tension spring pulled through.
I have a 49 year old Sears (Roper) with single cyl. 15 HP Briggs, and the deck is just fine.
Don't use it anymore though, as I have a nice new SCAG with a heavy fabricated deck.
   / What is the cheapest kubota zero turn diesel? #52
never remotely saw that on any deck, even the 800 dollar Walmart special
   / What is the cheapest kubota zero turn diesel? #53
Buying any air cooled gas engine nearing 2000 hours is a gamble I wouldn't take. Far too many are near the end.
Your blanket statement is not true. You ever owned a Kubota gas engined machine? The Kubota engines in Grasshopper mowers are the same block as diesels, just carburated instead of diesel.
   / What is the cheapest kubota zero turn diesel? #54
The key word RickB said is Air cooled, that can substantially shorten the lifespan of a gas engine. The water cooled Kawasaki and Kubota gas engines will have a much longer life span.
Typical life span of an air cooled small gas engine is around 2-2500hrs as a best case most comercial mowers are operated near full load in harsh environments typically and may not see the best maintenence, I think 2000hrs would be a gamble.
   / What is the cheapest kubota zero turn diesel? #55
I said it was a gamble, not an absolute guarantee of failure. And I'm not backing down from my post. If you read slowly you might see I mentioned air cooled gas engines. If you don't agree that's fine.
   / What is the cheapest kubota zero turn diesel? #56
The good Kubota gas engines are also liquid cooled.
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
1326 (A58374)
1326 (A58374)
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
JOHN DEERE 4760 TRACTOR (A52708)
JOHN DEERE 4760...
