What is the cheapest kubota zero turn diesel?
   / What is the cheapest kubota zero turn diesel? #51
I never said they rot, the decks are so thin the tension spring pulled through.
I have a 49 year old Sears (Roper) with single cyl. 15 HP Briggs, and the deck is just fine.
Don't use it anymore though, as I have a nice new SCAG with a heavy fabricated deck.
   / What is the cheapest kubota zero turn diesel? #52
never remotely saw that on any deck, even the 800 dollar Walmart special
   / What is the cheapest kubota zero turn diesel? #53
Buying any air cooled gas engine nearing 2000 hours is a gamble I wouldn't take. Far too many are near the end.
Your blanket statement is not true. You ever owned a Kubota gas engined machine? The Kubota engines in Grasshopper mowers are the same block as diesels, just carburated instead of diesel.
   / What is the cheapest kubota zero turn diesel? #54
The key word RickB said is Air cooled, that can substantially shorten the lifespan of a gas engine. The water cooled Kawasaki and Kubota gas engines will have a much longer life span.
Typical life span of an air cooled small gas engine is around 2-2500hrs as a best case most comercial mowers are operated near full load in harsh environments typically and may not see the best maintenence, I think 2000hrs would be a gamble.
   / What is the cheapest kubota zero turn diesel? #55
I said it was a gamble, not an absolute guarantee of failure. And I'm not backing down from my post. If you read slowly you might see I mentioned air cooled gas engines. If you don't agree that's fine.
   / What is the cheapest kubota zero turn diesel? #56
The good Kubota gas engines are also liquid cooled.
(APPROX. 20) 4' X...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2018 TowMaster T-12D 7 Ton T/A Flatbed Trailer (A55852)
2018 TowMaster...
