What is the best way to level truck when towing?
   / What is the best way to level truck when towing? #21
I really like timberen I think they are called SES, I had those after having airbags and they are way better, you dont need to add air or balance them out, you dont feel them when you are not loaded. and they are less expensive. a no brainer in my opinion.
I run sumo springs front and back, and Bilsteins on my Chevy 4500 class C MH definitely helped with ride height, swaying, and excessive bouncing. If they had reasonably priced air bags for it installing without drilling in the frame probably would have went that route without a combiner valve instead.
   / What is the best way to level truck when towing? #22
Air bags allow you to keep the truck level so the steering components are all set properly.
   / What is the best way to level truck when towing? #23
On the OPs truck you shouldnt really need a WD hitch. All those tongue weights should be under the max capacity I believe. You also dont need a WD hitch for 500lb tongue weight on a 2500 series truck.
A WD hitch and rear spring rate devises like bags or timbres do different things.
   / What is the best way to level truck when towing? #24
I am a recent convert to weight distributing hitches. Except for the cost, there is no downside to using one. Brilliant piece of engineering.
   / What is the best way to level truck when towing? #25
One downsides of taking weight off the rear axle of the towing vehicle Is less rear traction. For a 4wd vehicle, this may not matter when trying to go, or you may never be in a situation where it matters.
For braking, more weight on the front axle has pro/cons. You may stop quicker with more front braking, but less weight on the rear mean it’s more likely to jackknife…unless the trailer braking is more effective (and not skidding, etc..) than the lightened rear wheel braking of the tow vehicle.
   / What is the best way to level truck when towing? #26
If you actually read your owners manual, almost any pickup truck other than brand new HD's will REQUIRE a weight distributing hitch when towing above 5000 lbs on the hitch. Even my old 2500HD did. Did I sometimes tow heavy without one? Sure, but legally it was required. WDH's are great.
For my new F150, I have my eye on a set of these bad boys. No legal increase in payload or towing, obviously, but much more competent load handling, under all conditions. Almost seem too good to be true....
To answer an earlier comment, yes my truck has the tow package with the class V receiver.
I must say you folks have given me more options that I ever knew existed. Lots of options to think about. The boat trailer is very consistently loaded, with the tongue weight always being the same. Box trailer and flat bed trailer, not so much. I know in an ideal world how much I should be loading the tongue, but that is not always possible. I need to research a good deal more to see what is best for me before I make a decision. Thank you for all your comments so far.
   / What is the best way to level truck when towing? #28
I take it you never used a WD hitch?
The WD transfer will never be more weight on the front axle than the rear axle of the tow vehicle!
The WD is just used to transfer SOME of the hitch weight to the front versus all of the weight being on the rear axle and therefore making the front axle load lighter.
   / What is the best way to level truck when towing? #29
Since you have a Class V hitch I wouldn’t add anything to your truck. Just make sure it really is a Class V, they take a bigger shank but many have an adapter. It’s confusing because most class IV hitches have a V on them, which has something to do with the steel in them. A picture of mine which has a V5 on it but is not a class V.
   / What is the best way to level truck when towing? #30
Who said front axle weight will be more than rear?
That’s a function of the specific tow vehicle combined with the trailer’s weight and how distributed.
Like I said, there’s LESS rear traction with a WD hitch because there’s less rear axle weight than with a non-WD hitch. LESS weight on rear axle, and more on the front axle increases chances of jackknifing. …thus increasing dependency on trailer brakes operating perfectly.
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A57880)
2007 TEREX ADVANCE...
2020 DRAGON ESP...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
