/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,801
MF or my dealer may be aware of the clip problem. My brand new mower has the clips on the inside.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,802
I think I had mine on the inside when it yanked out. But then again I was using my mower deck like a brush hog.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,803
Well, I'm getting better at this... After using the FEL and BH to handle firewood logs, I --once again-- went through the conversion from TLB to lawn mower and hit our lawn yesterday. Now taking me only about 15 minutes to drop off the BH and the FEL (I leave the MMM on all the time in the summer).
Still like to stand back and look at the result -- that LRB/MMM sure does do a nice job.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,804
2021 GC1725MB oil light on, oil is splashing under valve cover.
oil pressure sensor part# 7082722M2 56$ with tax and 5 minutes of work.
neighbors tractor now fixed.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,805
Over the past few weeks have gone through several iterations of my tool storage issues and think that I have it dialed in. Also got my winch mounted.
Attached some metal channel framing (strut), AKA Unistrut or Superstrut, to the ROPS with some long U-bolts that I got from the Bolt Depot. Then built a wooden tray and mounted it to the strut with angle braces.
Next I got my winch attached to the top of the 3 point trailer hitch.
The wireless controller of the winch is mounted under the tool tray. I used Anderson connectors to be able to disconnect the winch from the controller.
Next I mounted a strut crossmember to the vertical strut and then attached an ammo can to use as a tool box to the strut. It fits nicely behind the seat and is easily accessible.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,806
saved this to desktop for ideas for my gc2400
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,807
2021 GC1725MB temp gauge going wild, top and bottom hoses different pressures and temps.
ok replaced t-stat (old one gummed up, cleaned up for spare dropped new one in) and now fluid all flowing right.
t-stat part # 3704299M1 68$ from warrenton equipment.
BUT....gauge still acting wild.
engine off for hours, ambient temp 75 and engine,coolant,etc running 80-85F no matter where I checked.
turn key on gauge goes up half way drops down shoots back up to halfway.
unplug dash (have to in order to ohm sensor with wire attached) and at 85F ohmed 350-400ohm swinging back and forth. should be 600+.
ran engine good amount to warm up. coolant running approx 140F all parts of engine running 145-155F.
gauge full red.
ordered new sensor.
this uses the newer style with nut on wire vs push on wire. part # 7080879M1 87$ from warrenton equipment. free shipping (was fast shipping) on both parts to Maine.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,808
have this unit for garden work, complete with all accessories.
very handy tool.
today I pulled one blade off reversed the other, offset toolbar and weeded beside my rows with the tractor.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,809
I've got the mower deck on and just mowing 2 yards these days, FEL and BH are off. Too dang hot to do much else!
I'm learning this thing mows really well, and rides rough due to this cheap ass seat.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,810
Added some metal channel framing to the side of my forks so that there is something to attach the ratchet strap to. The straps help keep the logs in place where they are being moved from the lower field to the pile near the house.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58214)
2019 MERTZ...
2183 (A58376)
2183 (A58376)
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2017 MACK CHU613 MID ROOF SLEEPER (A58214)
2017 MACK CHU613...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
