/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,491
My 2007 (started life Feb. of 2008) 2310 is now showing 1195 hrs. (Ray: "Still ticking" on the OEM battery....!:love:)
Unplug it for 2 days, let it sit, and let's see it start. :p
I do have 6.5 years on my current battery, which is a Deka, under the O'Riley label. Deka was rated well for tractor vibrations.
Tried everything else I ever found to be reliable. They are all crap now. None of them lasted more than 4-5 years.
My Amsoil ATH trans oil, has 400 hours on it, even though I did not plan to do it, I'm going to replace it in the spring.
I drained a sample during fall maintenance, and found it to have darkened some.
The price of the semi-synthetic Permatran is attractive. So, I'll give that a go.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,492
"Unplug it for 2 days, let it sit, and let's see it start. :p "
Ha-ha! I do plug it in Ray, but only (so far) for the block heater. When it gets really cold, I'll occasionally need a charger on the battery, too. And you're right, after it has sat for a few days it's always harder to start.
I also think Deka makes a good battery -- I just replaced all four coach batteries in my RV. They were "only" 9 years old, but had been heavily stressed twice, once by me (left inverter turned on for several days-- still kicking myself over that one) and more recently by being over-charged by the additional alternator on its engine (still have to fix that issue).
It came with Deka deep-cycle AGM golf cart batteries, and I replaced them with the same -- 8AGC2 6-volters, in a series-parallel arrangement. $400 each. Ouch.
So the ol' 2310 is now finished with mowing & leaf pick-up duty, so I need to pull the MMM and service it, then get out the blower... but I really wrecked my back pulling those RV batteries out of the front location -- they're 70 pounds each!-- so I'll need to get some assistance removing and then standing the MMM up; I know I can't do it by myself any more. Age is finally catching up, I guess. Damn.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,493
more of a what did you buy FOR your GC kind of post.
bought a trailer to haul snowblower to Dads house 30 miles 1 way if needed. blower with bucket is just over 15ft long and the 14ft single axle was too short and was technically overweight. this is 7x20.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,494
Not sure where I'd put it, but there are times I wish I had a trailer like that!
My 2310: finally pulled the MMM, in the process of servicing that... then on to wood pile moving and getting the blower out.....
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,495
I'd put it on the ground if I were you. too heavy to float :)
800 hours on the MF, only 200 hours to go and it will be new again like irvingj's.
10 degrees this morning and another dusting of snow last night.
Switched to the rear weight box and the MF Dozer Blade a few weeks ago and today I'm going to install the tire chains.
Guess I had to wait until it cooled off a bit to install the tire chains, ha.
Anyways last weekend I swapped the tires/wheels on the F150 to the winter studded tires.
Guess we have had about a foot of snow total in the last 2 weeks, winter is a coming.
Picture is a few Whitetails on the lookout for a buck this morning.
KC
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,497
I’ve got 2 cars to swap snow tires onto tomorrow. Then I have to pull the loader and hoe off of the gc2410 and put the snow blower on. Supposed to get 5-8” here Thursday and Friday.
Sucks because I still have some loader and hoe work i was hoping to get done yet this year. Hell I just got my leaves and beds cleaned up today. Oh yeah, have to wash the gc and my zero turn tomorrow too. ZT is filthy from using the power bagger.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,498
Well, the fun never stops! Got the MMM off, serviced & put away, pulled out the 2360 blower...and noticed a wet, oily spot under it....
Yep, the seals on the blower gearbox --at least the one on the right side-- is leaking. I'm guessing it's lost half its oil, so now a decision: fix it now, or try to get through the winter with it as is?
And I just rebuilt the whole gear reduction chain drive a year or two ago -- new chain, sprocket, stub shaft/sprocket, couple bearings... Now it looks like the whole thing will have to come apart (again) to get at those seals in the auger gearbox....
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,499
if not fix it now at least get the suspected needed parts in hand to prevent down time at the worst possible moment.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,500
Way ahead of ya! Ordered this AM. In the meantime, I guess I could always add gear oil periodically.
An interesting aside -- Kubota's blower is also made by RAD Technologies in Canada, and they share many parts (but not all). Our local Kubota dealer was willing to order their "Seal Kit" for their stock, so I can compare it to the one from M-F. The K-place is only about 35 minutes away, as opposed to the nearest M-F dealer, which is 1-1/2 hrs away for me.
Not surprisingly, Kubota's seal kit lists for $43.70 while M-F's is $68.84. That's about typical, I've found: M-F parts --when they're demonstrably the same-- will run around 35% more$$$ than the Kubota part. (My blower now has quite a few Kubota parts on it -- shear pins, scraper blade, reduction sprocket & chain....)
John Deere D155 Lawn Tractor (A55758)
John Deere D155...
Decorative Metal 5-Point Star (A55758)
Decorative Metal...
Club Car Carryall Utility Electric Golf Cart (A55853)
Club Car Carryall...
CAT EXCAVATOR BUCKET (A55745)
CAT EXCAVATOR...
Rigid Wet Dry Vac (A54865)
Rigid Wet Dry Vac...
2014 JLG 4550AJ SERIES II MANLIFT (A52706)
2014 JLG 4550AJ...
