/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,921
I don't need to reach that high, I don't even have the optional 2' extension for it ... 😁
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,922
First season with the tractor and MMM. First time removing a blade to take measurements. Have already read Gator blades not available for this deck. With leaf season upon us, I will find one that is close and modify to fit.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,923
MF loves proprietary parts. :(
If they did offer Gator blades, they would be $100 a piece anyway.
They are a must for me
If you have a chute deflector, or a cover, G5 or G6's shred leaves nicely.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,924
Well, this wasn't today but recently :). I tried out the MMM that I got with my GC2300 with the thought of moving my cyclone raking duties to a tractor that has power steering and lift. Even though the deck's blades are in terrible condition, it cuts very well and is a lot of fun to cut with. I ordered the kit to hook up the CR to the Massey and it works well. Now I'm just waiting for the leaves to start dropping.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,925
Started getting tractor ready for winter, removed the MMM, moved the snowblower up from storage and put on the FEL. Then I used the FEL to knock down the corn in the garden, need to do this or it causes bad drifts come winter.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,926
Yes, Eric, I've noticed the same with my MMM -- I used to sharpen the blades numerous tines during the mowing season, but discovered it really doesn't seem to make much difference -- even with relatively dull blades, that MMM still does a good job!
Used mine for a second round of leaf duty Saturday, using my DR Lawn & Leaf Vac. Works very well. Probably at least one more round before my LRB gets converted to snow duty.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,927
in an average mowing season I do swap blades, in my particular situation it does make difference. I keep full set ready to go. hay and clover dulls blades fast.
today cleaned underside of deck and put fresh set on so first mowing next spring its ready to go. just have to grease it and tarp it for season now.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,928
Got home today, and noticed my flag was getting frayed ... They don't make them like they use to ... Made in USA by Valley Forge flag, last two last until I replaced them at a year . . . This one has only been flying about 4 months!
Little Baby Fergie gave me a platform to stand on ...
Pulled up two of my raccoon traps by the barn, set the one I left, then went down to the creek where I saw some activity ...
Set two down by the creek, baited with brats!
Then checked on my creek while I was down there, we got 1.76" of rain yesterday! 😁
It's not full yet ... I'm parked in the "crossing" once full and flowing there will be water running from right to left ...
Almost 16" deep ...
Later we went out back to fetch some cement blocks that I used last time I was home to hopefully guide a armadillo into my trap, as I found a den entrance at the back fence line, but after 2 nights, nothing ... While mowing today I saw a place something had dug under the side fence . . .
Armadillos don't have good eyes and use there nose to follow trails, and dig up my lawn like mini rototillers! :mad:
We also carried another box trap up by my gate, as I've been seeing skunk(s?) on my camera up there ... While they do also dig in the lawn for grubs ... I just want it to STOP!
Six traps set tonight, in the morning we will make a "trap run"!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,929
Provided transport services from the front gate, to the back field ...
Skunks are the only critters I don't like to shoot in the live/cage traps ... They stink up the traps! So ... I take them out to a big open field and ... Let them go! Then shoot them!
Carried back out by the gate area, as I will plant a Forsyth cutting there in the spring, put it in the BH bucket, as I figured with the digging it would remove/scrape out any residual "stink" ...
All done, waiting for spring ... Nothing in the other 5 traps ... Maybe tonight?
I like to plant trees/bushes in the corners when possible, so I don't have to trim! 😂 There is a redbud planted last year with a armadillo companion in the corner on the other side of the fence ...
I did notice when backing back into the barn there still was some "stinkage" left!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,930
<snip> I rarely need or use 4X4, and if used properly like the manual calls for on ground that will allow a tire to slide or spin, like ice or mud, I can't see what difference how much weight is on the front would make a difference in wear and tear on the front axle ... <snip>
Bear in mind that the later model GC's have only one brake; earlier models had two (they had to be synchronized), but the effect is basically the same. They only work on the rear wheels, unless you are in 4-wheel drive. You have zero braking on the front wheels if you are not. Be careful out there!
Yeah, I know.
I rarely even use the brakes, it's more of a parking brake for me ... If it won't stay still on a slope, I'll use the brake to stop it from rolling, then apply the parking brake to hold it in place ... I usually have weight on the back tires for traction, helps in going and stopping.
Hate to bring this subject up again BUT just read a sad tale on the Orange Tractor Forum (OTT) where someone with a Kubota BXs tractor had a failure of his differential while in 2-wheel drive and lost ALL braking. The BXs transaxle is very similar to the later GC's and has a single brake which is upstream of the differential. It's 4-wheel drive for me all the time.
Here's a link to the thread: BX23s rear differential replacement.
2014 Ford F-550 (A55973)
2014 Ford F-550...
UNUSED Battery Powered 3 Wheel Golf Cart (A55272)
UNUSED Battery...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
