What have you done to your Branson today?
   / What have you done to your Branson today? #61
Here's the newly welded grab hooks on the Branson.
There also one I welded on the backhoe bucket and one on the 3-point hitch trailer hitch attachment.
   / What have you done to your Branson today? #62
It has been snowing hard for the last couple days here, and I have been welding hooks and clevis mounts to my front end loader. Today I was going to figure out how and where to mount a tool box, but I watched Football instead.
   / What have you done to your Branson today? #63
I never thought of welding a hook to the drawbar .:duh: Huh, Looks like I'll be welding one to my drawbar.:)
   / What have you done to your Branson today? #64
I ordered 10 hooks for 64 bucks including shipping, Grade 70 3/8" so I started brainstorming where I was gonna mount them.
I ended up welding 9 of them but ran out of places.
   / What have you done to your Branson today? #65
I'm gonna mount a toolbox somewhere behind the seat.
It looks like if I move my "slow moving vehicle" triangle reflector back a bit that there should be room there.
   / What have you done to your Branson today? #66
With a cab, there is no room behind the seat, and it is not a convenient place anyhow. I too could remove my "slow moving vehicle" sign and mount it there. But on mine it is above eye level. A fixed tool box would require using the "feel method" to find stuff inside. So it would have to be easily removable without being self-removing over bumpy ground. Still scratching my head. I bought an ammo box at Harbor Freight and painted it red. It should work good as a waterproof tool box. The only thing that won't fit in it is my hammer (most important tool for a mechanic of my skill level:)) I will go work on that today.
   / What have you done to your Branson today? #67
I too have a 4720,look on top of the rear right fender there are some holes with grommets in them.Remove 2 or 3 of the grommets,buy a cheap sears tool box (many sizes available) they are already the right color.Put a few strips of weather stripping on the fender so you do not scratch it. Mark the bottom of the box thru the holes and drill them.Works great.
Dan
   / What have you done to your Branson today? #68
Dan
I too had thought of the fender location but I'd actually like to buy another cupholder from Branson and install that so I have one on each fender. Those suckers seem to come in handy for me.
   / What have you done to your Branson today? #69
I think the 4720H and 4720CH are quite different in regards to available area on the fender. Attached are the pictures of how I finally mounted the ammo (tool) box. Was quite a trick to find a place that wouldn't interfere with the rear window opening, didn't hang out to where it would get knocked off, and I could remove it easily (too high to easily get inside where it is mounted). Also I included pics of my clevis mount and hooks I put on the bucket. Not the best welding job in the world, but they will hold.
   / What have you done to your Branson today? #70
Cougsfan, your old 70's dirt bike has a recoil starter on it... ?!?
I've only seen that on FL250 Honda Odyssey engines.
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
PALADIN INDUSTRIAL SCREENER (A58214)
PALADIN INDUSTRIAL...
flooring (A55758)
flooring (A55758)
2021 Caterpillar 308 Midi Excavator (A55973)
2021 Caterpillar...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
