What have you built to do trenching with
   / What have you built to do trenching with #11
I had to run 250' of water line. I used a sub-soiler to break up the soil AND ripout all the roots, 3 passes. After that removed the chisel point and attached a 15" potato blade. It worked wonders, took me longer to change the blade and down 3 VERY COLD BEERS /forums/images/graemlins/cool.gif than it did too dig the trench.
   / What have you built to do trenching with #12
</font><font color="blue" class="small">( Less you're REAL good on the tractor,it may be hard to keep it in the trench for several passes. )</font>
I wonder how allowing the lower arms to travel side to side would work? Leaving out the pins or unscrewing the turnbuckles... undoing whatever is used to hold them fixed and keep your attachments centered.
Just a thought.
   / What have you built to do trenching with #13
We had no stays on the Oliver.
</font><font color="blue" class="small">( I wonder how allowing the lower arms to travel side to side would work? Leaving out the pins or unscrewing the turnbuckles... undoing whatever is used to hold them fixed and keep your attachments centered.
)</font>
That's a good idea Remove the stabilizer bars and let it follow the trench on each pass.
Pooh Bear
2018 Yamaha Waverunner Jet Ski (A59231)
2018 Yamaha...
2022 Behnke Trailer (A55973)
2022 Behnke...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
International 9200 (A56438)
International 9200...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
