What have you built to do trenching with
   / What have you built to do trenching with #11
I had to run 250' of water line. I used a sub-soiler to break up the soil AND ripout all the roots, 3 passes. After that removed the chisel point and attached a 15" potato blade. It worked wonders, took me longer to change the blade and down 3 VERY COLD BEERS /forums/images/graemlins/cool.gif than it did too dig the trench.
   / What have you built to do trenching with #12
</font><font color="blue" class="small">( Less you're REAL good on the tractor,it may be hard to keep it in the trench for several passes. )</font>
I wonder how allowing the lower arms to travel side to side would work? Leaving out the pins or unscrewing the turnbuckles... undoing whatever is used to hold them fixed and keep your attachments centered.
Just a thought.
   / What have you built to do trenching with #13
We had no stays on the Oliver.
</font><font color="blue" class="small">( I wonder how allowing the lower arms to travel side to side would work? Leaving out the pins or unscrewing the turnbuckles... undoing whatever is used to hold them fixed and keep your attachments centered.
)</font>
That's a good idea Remove the stabilizer bars and let it follow the trench on each pass.
Pooh Bear
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
