What happened here to my tire?
   / What happened here to my tire? #21
Yeah I think we need to steer clear of using explosives to seat a bead if you are a beginner.
Colonel Mertz von Quirnheim:
Any problem on Earth can be solved with the careful application of high explosives. The trick is not to be around when they go off.
Thats why I gave no instructions in my reply.
But it works very well.
Thanks to All. Good advice. This morning I tried the lift up with the FEL and squeeze the tire with a ratchet strap method. Success! I was parked next to the barn and had a 300 psi compressor to use, which definitely was convenient. Had to apply a tiny bit of silicone gel to one spot on outside rim to help the bead slide over, but the ratchet strap did the trick! Thanks again.
   / What happened here to my tire? #25
Make sure you video this method if you use it and then post it here!
Maybe:
Make sure you video this method if you use it and then have someone post the remains here!
LOL.
   / What happened here to my tire? #26
Maybe:
LOL.
I saw this done in person once on a tractor. The guy that did it had obviously done it before. The only advice he had to offer on this technique was "Don't tell my Dad I did that!" :LOL::ROFLMAO::LOL:
   / What happened here to my tire? #27
Pale of tire soap is cheaper than a cheetah and less noisy
   / What happened here to my tire? #29
Nice thing about using starter fluid to reseat a bead is it also inflates the tire a bit as well so you don't need much air to get it up to pressure either.
I don't recommend it for the faint hearted however. In fact I don't recommend it at all but it does work if you are so inclined.
   / What happened here to my tire? #30
I thought sure we would hear that having a bunch of hot air onboard is all you need if liter fluid or compressor isn't available.;)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 Audi A3 AWD Sedan (A56859)
2016 Audi A3 AWD...
2007 Jeep Wrangler Rubicon, VIN # 1J4GA39197L104496 (A57453)
2007 Jeep Wrangler...
2013 Genie GTH1544 Telehandler (A59213)
2013 Genie GTH1544...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
CASE CX160 (A55272)
CASE CX160 (A55272)
