What engine driven wlder
/ What engine driven wlder #11
Industrial Amp Arc ? Never heard of. That would have to be even less heard of than the Thermal Arc Preditor Pro. ( 1st one with Honda Engine ) :confused:
Its northern tools house brand (northern industrial) engine drive. A chinese engine drive, similar in specs to the lincoln outback, with a little less amperage, and a bit more genset wattage. Heres a link.
Northern Industrial Welders Amp Arc 7000 DC Arc Welder/AC Generator — 170 Amp DC Welding Output, 6000 Watt Power Output | Welders + Generators | Northern Tool + Equipment
/ What engine driven wlder #12
I like my miller.
another option would be a buz box and a generator, I bet all in you'd maybe be even or less than engine driven and you'd have a dedicated generator in the end.
I have a bluestar, if I had to do it again I would've just gotten a nice used buz box and ran it off of my generator, I have no issues with transporting both machine for the infrequent times I need portable.
Joel
/ What engine driven wlder #13
I've done a fair amount of welding, most of it with Lincoln rigs. Never had a problem with any of them. The thought of using a generator with a buzz box is interesting...lots of the small Lincoln boxes out there.....
/ What engine driven wlder #14
Im looking into a miller wildcat as we speak. Gonna wait a few wks till my LWS has there annual trade show, deals galore, plus job discount, and I personally know the owner. Only weighs 250lbs and has pneumatic tire running gear. Can easily adapt it to pull around with a atv. I was told miller is no longer gonna make this model, due to its portability they sold like mad and got abused to death. Too much warranty issues. Welding companies bought em up and would run 5/32 for ten twelve hrs a day through them. Research it on the net for all the info. Perfect for my needs, light enuff to get in my truck or drag around anywhere for about $2400.
/ What engine driven wlder #15
I upgrade an olderMiller 225nt last year to their 250, love it.
/ What engine driven wlder #16
I haven't done any price comparison in quite some time, but years ago generally Millers were cheaper. If you walked onto a construction site and seen all Miller machines, you could bet your bottom dollar some purchasing agent was ordering the machines, not anybody who actually ran them for a living. ;)
+1 and more than a few pipeline companys would not let you on location with anything but a Lincoln. CJ
/ What engine driven wlder #17
Yep, Ford versus Chevy. If I were doing pipe work or other construction work all day, every day, I'd run a Lincoln diesel. But I understood the OP's situation as building a fence, then general maintenance and other occasional work around the farm. In that case, either Miller or Lincoln will be fine. And wasn't price one of the OP's concerns?
I have a chance to get a Hobart Champion Elite with 5 hours on it for $1500. It's about 3 years old, has been outside so it shows some weather. It isn't the new enclosed model nor the 11KW; it's 10KW. 75 foot leads. Needs a battery. Seems like a reasonable deal.
/ What engine driven wlder #19
I agree. I'm welder poor but if I had it all to do again I'd get a good gen set and an inverter welder to go with it.
A friend bought a welder from this outfit. it goes against my grain to buy Chinese but if the U.S. vendors are just rebranding and of course some aren't there isn't much difference. He bought a combination of inverter welder and plasma cutter for a great price. The customer service has been great and the thing welds and cuts really really well.
I'm rigging up a welding trailer around a 20KW diesel gen set with all plug in welders, plasma cutter and torch. It doubles as a whole house gen set in a pinch, field welder, field shop with tools, drill press, chop saw etc. I've rigged it up for shore power while parked in the shop where I plug it into 50A service, collapse the tongue and push it up against the wall... welding table and tool room in the shop.
Maine Diesel is a good place for the gen set.
I have a Hobart 10KW that lost a card at less than 100 hours. It was out of warranty on time and cost me $750 to fix. Had to fix it since it was worthless otherwise.
/ What engine driven wlder #20
Trailblazer, Bobcat, or Ranger welder in the Miller and Lincoln series. All have 10K generator power.
Sounds like you are just going to use it for various projects for yourself. Since you are not going into the pipeline business I would look at the above machines.
Many contractors use these machines in structural and boiler construction. Lots of code work done with them.
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
(INOP) 2015 POLARIS SPORTSMAN ACE 570 (A59823)
(INOP) 2015...
