What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #491
One thing nice about forks that a bucket isn't so good for: you can reach over an obstacle, and tilt them into dump position, and have a tool for pushing things on the far side of said obstacle. I was rearranging felled tree trunks this way just a few days ago.
Now, I think I'd also like to buy just one fork, a short one of only 20 or 30 inches length, and sharpen its end to use it for digging. Maybe even weld a tooth onto it, like a subsoiler or ripper. Maybe some day.
   / What else do you do with forks besides lift pallets? #492
My double decker for reaching higher, yeah I know the tire needs some air. Cleaning out the barn owl box for the upcoming year.
   / What else do you do with forks besides lift pallets? #493
I've dug a million trees and stumps up with forks.
   / What else do you do with forks besides lift pallets? #494
Love a good set of forks; if you have a minor in welding, try fabricating an adapter for your forks to work with your 3PH (SSQA plate), great for moving just about anything that does not require height. I've used that method for large balled trees (burlap and cage) and you can precisely drop them where needed.
   / What else do you do with forks besides lift pallets? #495
I made a set of independent forks for getting under things that are not flat on the ground:
Picking up a RR tie that is at an angle to the ground:
Setting the angle of the forks by curling down:
Backed up and got under the tie:
Picked it up:
Curled up and raised for transport:
Xfaxman---very good
   / What else do you do with forks besides lift pallets? #497
Mr. Xfaxman, those forks will show back up on TBN 40 years from now!
"...Just found these at an auction...anybody know what they are?..."
It will be a thread with 400 posts, each trying to guess what they are used for!
Someone will say "They're for removing the triangular stacks of pallets we see in fields" while someone else will say "Phooey; I heard they're for removing stuck drain plugs on the early Ford tractors. It's called the Kando option". Someone else will say it's "to hold a borescope to look into holes in grain bin floors to look for the culprit". :)
And so, the cycle begins anew. :)
   / What else do you do with forks besides lift pallets? #499
Probably mentioned already but forks work great for small scale trenching. I used mine to dig about 40 feet of trench 18” deep just last weekend. Took almost an hour but it beats doing it by hand or spending hundreds to rent a trencher.
   / What else do you do with forks besides lift pallets? #500
Probably a lot sooner than 40 years :)
Yep, if they are not with the other TORO+Loader stuff it would be hard to tell what they are:
CFG Industry XZ20R Mini Excavator (A57149)
CFG Industry XZ20R...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2021 Ditch Witch SK800 Mini Skid Steer Loader (A57453)
2021 Ditch Witch...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2004 Timber King TK350 Wheeled Feller Buncher (A59213)
2004 Timber King...
