What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #381
Here is another lift sling application I used with forks the other day.
Two slings lifting a 5500 pound shear with forks
   / What else do you do with forks besides lift pallets? #382
I used mine to raise my 60 gallon air compressor off the pallet and into place so it could be bolted down to the floor.
   / What else do you do with forks besides lift pallets? #383
I have a project but not sure how to go about it. I have a 24" diameter x 24" long section of reinforced concrete pipe that I want to put over my well pipe to keep anyone from driving into it. It weighs 500 lbs. How can I do this the right way with forks?
My plan was to just stand it on end and set it over the well pipe sticking out of the ground but there's a risk I could drop it on the pipe. A construction guy told me they use some sort of strap thing and it just picks the pipe up and sets it where you want it. I can't find the guy that told me this and have no idea what he's taking about.
Does anyone have any thoughts on how to go about getting the 500lb piece of concrete pipe over my well head safely?
This over your well head will not be a problem for a real well man. It is wide enough to get the cap off for pump troubleshooting and if the pump has to come out then either you or he can move it out of the way. A good pump man is not helpless.
   / What else do you do with forks besides lift pallets? #384
Wasn’t a fan of the hole in the end of the fork method so I welded a receiver to mine. Works great, and keeps the weight closer to the pivot for the heavy trailers.
   / What else do you do with forks besides lift pallets? #386
Wasn稚 a fan of the hole in the end of the fork method so I welded a receiver to mine. Works great, and keeps the weight closer to the pivot for the heavy trailers.
Yep, very handy:
Makes it a 90 degree dump trailer :D:
   / What else do you do with forks besides lift pallets? #387
Been meaning to post this for a while now. It's kind of a variation on Cat_Driver's use-as-a-table.
Should have taken a picture but sawed a heavy 10' log into manageable portions by lifting on the forks, sawing the overhang off on each side and then sawing in the middle between the forks. Easy to do, solved my problem and kept the saw out of the dirt.
   / What else do you do with forks besides lift pallets? #389
I use my forks to lift my PullRite 5th wheel hitch out of the bed of my truck. Really handy, considering the hitch weighs much more than I can lift myself.
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
Rooster Weathervane (A55853)
Rooster...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Sedan (A59231)
Sedan (A59231)
