what does your electricity cost?
/ what does your electricity cost? #21
Here in N Idaho, were hydroelectric supplied, and the rate is $0.055/KWH.
/ what does your electricity cost? #22
Latest bill from Philadelphia Electric (PECO) jumped significantly due to their elimination Jan 1 of the 40% discount for winter heating
in all electric homes. My consumption was down a third from last year, and it said the average daily temp was the same, 40 degrees, but the bill
was way higher.
My bill says I'm paying a rate, the number "to compare" of .0869 per kw of power.
How does that compare to what you are paying?
Boy am I glad I redid the windows, insulation and siding a couple years ago. Brought my consumption down significantly, but sadly apparently my
bill will do nothing but go up.
Your getting a deal!!! We pay $0.125/KWH
/ what does your electricity cost? #23
We pay 10 to 11 cents per KWH but that includes all fees and taxes. I have tracked our power usage and bills since we built our house. I calculate the KWH costs with the total KWH used during the billing period and what I paid to the power company. The KWH cost would be a bit lower but the power costs is what I have to pay the power company which includes taxes and fees.
I hear people in my area complaining about the cost of power going up but has not increased. Their USAGE may have increased but the cost per KWH has not.
Later,
Dan
Here in SC on SCEG our bills in my house that I have owned for say 4.5 years has gone upclose to 0.02/kwh. Our power excluding fees is more than yours. YES my bill has gone up.
To the OP I use wood heat and I can keep my tv room up to 80+F in the winter and the rest of the house at 70ish and bed room is 66, and other 2 bedrooms is 70+.
I have no wall insulation and keeping my far bedrooms heat on say 55F and the other one on 65f my bill would run $250 in the winter months, with the stove we pay $115, unless like this last month we had 8 people in the house and they still insisted on closeing the door and running the heat pump to stay the same temp? plus all the lights and extras associated with holidays!!!
/ what does your electricity cost? #24
OK I was wrong I just did the math I was at $0.151/kwh for just dividing power cost by kwh. But there is one rate for like first 1000kwh and then a different one for everything above that. if I divide all the taxes fees and cost by kwh we get $0.152.
But this bill did have something like they are charging me another $25 for some weather normalization fee??
EDIT just looked up what this was and... copied from site..
"Electric Weather Normalization (WNA)
Your heating and cooling system is the biggest user of electricity in your home. When outside temperatures are unusually high or low, your energy costs can spike significantly in a given month. To help take some of that weather-driven volatility out of your electric bill, SCE&G introduced the electric Weather Normalization Adjustment – or WNA – program in August 2010.
What is the WNA and how does it work?
With WNA, you are charged for the energy you use at a rate that’s adjusted to reflect normal temperatures. “Normal” is based on average temperatures over the past 15 years for a given billing period. Each month, WNA appears on your bill as either an increase or decrease to the cost you’re paying per kilowatt hour of electricity. A minus sign in front of the WNA factor indicates your rate was adjusted down for that bill. A plus sign signifies your rate was adjusted upward.
Why did SCE&G implement the WNA?
The goal of the WNA is to reduce the effects of extremely hot or cold weather on the customer and the company. The WNA helps reduce large spikes in your electric bill during periods of extremely hot or cold weather while also allowing SCE&G to continue to recover normal operating costs and provide you with safe, reliable electric service in any weather condition..
Conceptual representation of WNA
Click to enlarge
Will my bill adjust every month with the WNA?
It is possible that your bill will change from one bill to the next based on weather. Adjustments are indicated by an increase or decrease to the cost per kWh. A minus sign in front of the WNA factor indicates your rate was adjusted down for that bill. A plus sign signifies your rate was adjusted upward.
How is the WNA rate determined?
The method used to determine the WNA factor is approved by the Public Service Commission of South Carolina (PSC). It is unique to each customer based on type of residence, rate and other individual billing factors. It also changes from one bill to the next based on weather.
Will the WNA make all my bills the same amount?
No. The WNA is not the same as SCE&G’s Budget Billing Plan, which totals your annual electric usage and averages it over 12 months so that your bill is the same amount each month. To learn more about Budget Billing, please visit our Budget Billing page."
Strange I just looked up rates and they say $0.128 and $0.123 for the hours over the first 800. This is the winter rate the summer rate is a few pennies more an hour. I have no idea why it adds to more than this without fees, sounds like I need to call the provider, and maybe switch my rate plan to a time of use one.
/ what does your electricity cost? #25
I am surprised that your rate is so high. Ours is .11, and that is with all the extra charges folded in. We do have a peak and off peak charge, but I only looked at the final numbers, so that .11 is a blend.
/ what does your electricity cost? #26
that WNA fee I mentioned put it up to .15/kwh it should be about .125/kwh, after seeing a video on this program it takes out spikes from extreme cold or hot and helps even out your rate, this is not budget billing. I have no idea why this year we got an increase i guess because this year was hotter than normal which should give me a rate increase or if it was colder than normal i would get a decrease?? Let me pay for what i use is all i want!!!
/ what does your electricity cost? #27
AEP in WV is charging 9.4 cents for the first 500KWH and then its 8.3 cents for each KWH there after plus a $5 monthly customer charge.
/ what does your electricity cost? #28
Man i wish i had some of yalls rates, i would not freak out as much when a random light is left on. And we even have CFL's!!
since it's real important to compare apples to apples, I'm not sure my "rate to compare" is the same
as your "rate to compare", which is unfortunate. But for those of us who just have one rate, it's not a huge swing.
I never switched from PECO, though the free market now has unleashed dozens of companies calling me to see if I want to buy electricity at a substantial
savings, which is rarely substantial, and at most ten percent for a limited time. But no one has called me about solar panels, not that our HOA would allow them anyway.
Those of you with hydroelectric power seemed to have the lowest rates. Many of those plants, which I've been on, are a hundred years old,
and older. And still doing their job. Awesome machinery, lots of historic brass gauges still on them, visit if you can.
No pollution, very little noise, and great fishing nearby. But then I like anything near the water.
Absolutely agree that solar and wind is the way to go in the wipe open spaces where you have a true natural resource in sun and wind.
Not sure anyone other than an engineer could look at a wind generator and think it's attractive, but then solar panels don't exactly come in camo either.
We need stealth tech for both, if you don't see them they won't bother you. Assuming you aren't flying a small plane that is...:eek:
update: anyone remember if there was ever a thread on "what's your thermostat set to?". I would find that seriously interesting, but might use up more bandwidth
than it's worth.
/ what does your electricity cost? #30
I thought my rate was high but after reading here, I will be quiet. December useage came out to $.0999 KWH. Rate hasn't changed in past 12 months.
Here in the Sunbelt, the smart thing to do is go solar and never look back.
We have a 10.3 system with a mix of older (3 year old) 30 BP panels with 18 newer panel (this spring) with built in inverters.
It has eliminated our electric bill, well we still get one but they owe us.
This is on a 3000 sq ft home. Well insulated plus double pane windows.
TXU settles up monthly now for what we put back in the grid at .750 per kWh.
TXU charges .1290 per kWh plus the extra charges.
With our two CNG powered vehicles, a 2011 Honda. A 2004 F150 crew. I feel like telling big oil & OPEC where to stick it.
Seriously nice going. Impressive accomplishment.
/ what does your electricity cost? #32
I pay 23 cents per KwH. You guys have got it good. Still, because I installed a small solar system, I got a credit of $60.00 the last bill.
Wow. That's at least double and maybe triple what some of us pay. Oil fired generation or are we truly spoiled?
At those rates, solar has to pay for itself in a reasonable time. Glad you got a credit. That's a load of diesel for the Kioti!
And you appear to live (sorry, never been to your beautiful country) in the "populated" East, not too far from the coast,
so your transmission costs are likely as low as they'll get in your area.
Kinda like reminding us to stop complaining "here" of gasoline prices.
/ what does your electricity cost? #34
Well, the solar we paid cash for, so we don't look at it as needing to pay itself off, we just don't want any power bills. (or at least small ones) Yes we are about 80 - 90 klm from Brisbane in a rural area and the Government just put a stop to the power companies wanting to up their prices about 30%. Towoomba City is about 25 klm to the west of us. If you are interested you can watch this little video of our district, taken by my radio controlled glider. The little township is Grantham that was virtually wiped out by the flash flooding 2 years ago and you can see where they are rebuilding homes on a hill nearby. I was just trying out my new camera. https://vimeo.com/54428844
/ what does your electricity cost? #35
Here in NC using Duke Energy they break it down as follows:
Basic Facilities Charge: $9.90
July-Oct: .092898/kWh for the first 350 kWh
.092897/kWh after the first 350 kWh
Nov-June: .092898/kWh for the first 350 kWh
.084192/kWh after the first 350 kWh
I am positive these rates will go up due to their coal fired plants and new EPA regs...
As a point of reference, my utility bill runs around $2200 per year for a 1450 sq. ft. brick rancher built in 1953...
I have a heat pump and electric water heater...
Not relevant to you guys up North...
That heat pump would be pretty worthless in cold climates...
I do have gas logs for back up...
Marvelous video, what a cool glider, the propeller reminds me of a folding prop on a sailboat.
Nice flying, did you loop the plane toward the end?
DC powered motors?
/ what does your electricity cost? #37
I don't have my bill close by. But if I remember correctly I pay around 11 cents per KWH. That's before taxes and delivery charges.
My bill averages around $80.00 to $90.00 per month.
Chad
/ what does your electricity cost? #38
than it's worth.
Hydro power is not always cheap. There are 3 hydro dams (USACE controlled) that sell to the SEPA, which my electric company will distribute some, also SCEG has huge hydro lakes and small systems, any fishermen everheard of Santee?? Those fAmous catfish lakes known as Santee Cooper, that's my power co. They also have Nuke and coal which I think there burning more gas, but still look at my rates!!!
/ what does your electricity cost? #39
id love solar, but I looked at one magazine and found that I would need something over $100,000 worth of panels, plus install etc. I must have not been doing it right?? I WAS Looking at some green living catalogue and thought that they told you how to figure capacity based on current useage, which Is what I remember doing, but at those prices it would take 30 years to pay off even at my current rate!!
Tell me if Im wrong, I posted my stats above, I used 1400kwh last month. And that's a lot for the winter as I went to wood heat almost exclusively a few years ago. We don't leave lights on have cfl's and save where ever we can!
/ what does your electricity cost? #40
Actually far from worthless. We're very satisfied with ours. We have a 2800 sq. ft. split-level (open floor plan) house with a 1300 sq. ft. "in-law suite" addition, joined at the garages. They're stick construction with 2x6 exterior walls and R19 insulation (R38 ceilings). Each "side" has it's own heat pump, and electric water heater. Electricity is the only utility we have. Each "side" also has high efficienct woodburning fireplaces, but we only burn in the evenings, and usually only when the temperature drops into the low 30's and below (laziness and procrastination plays a role here :)). In 2012, we used 27,456 KWH, at a cost of $2266.85. I had always heard that heat pumps were not very efficient below 40 degrees, but have been surprised at how long they'll go to maintain a temperature before going into "auxillary heat" ($$$) mode.
