What do you do with your forks?
   / What do you do with your forks? #232
Home built manlift go swell with my Landpride Forks
   / What do you do with your forks? #234
Just for reference, I did a diverter setup for about $300. Pretty good, I think.
Like I said, not enuff $$$ currently, and while I love tractor toys for the tractor, there be many other things needed more urgently than a 3rd fcn or grapple.
Besides then I gotta buy the grapple too.
Lotto be good to me pls.
Thomas
   / What do you do with your forks? #235
PC060036.jpgPC030031.jpgThe bottom basket began as the shipping pallet for a Woodmaxx hydraulic chipper. I worked great, but I needed more height. So made another one to bolt down on it. Then I decided that I liked having it be easily and quickly switched on and off so I went with four inch steel C Clamps. The lower pallet deck is milled douglas fir two by lumber.
The upper basket deck is one inch plywood. Both decks are bolted and nutted through the angle iron tray. Underneath the top deck, I have PT two by four on each side, screwed to the bottom of the upper deck. On top of the deck is one inch wood. SO, My clamp points are spread out considerably with the use of those two boards. It is strong as can be . Oh and I forgot to mention, I have foam rubber strip between the the top of the lower basket and the bottom of the upper basket. It all makes for a nifty install.
In my view, the only slightly sketchy thing about those pictures are the C-clamps holding the 2 frames together.
Can I ask what you repurposed those from?
Thanks,
Thomas
   / What do you do with your forks? #236
View attachment 440051View attachment 440052The bottom basket began as the shipping pallet for a Woodmaxx hydraulic chipper. I worked great, but I needed more height. So made another one to bolt down on it. Then I decided that I liked having it be easily and quickly switched on and off so I went with four inch steel C Clamps. The lower pallet deck is milled douglas fir two by lumber.
Hi HSL,
Thanks for the reply and the details, I wasn't really meaning to troll you about the construction, I'm just jealous and trying to figure out what I can use to make my own.
In other words, nicely done!
Thomas
   / What do you do with your forks? #237
How about forks for donating an old TV to the local thrift store? It's a 34" flat screen and probably weighs 200#. I made a second trip and took the TV stand with a few extra things thrown inside.
   / What do you do with your forks? #238
   / What do you do with your forks? #239
You are lucky they will take that.
Around here the needy only want LCD's and thrift shops refuse all tube and projector types.
Our only option is the scrap yard.
I don't know if they want it or not but they have a room open 24 hours and you walk in and drop stuff off. I'm sure they get stuff they don't want.
   / What do you do with your forks? #240
By the time we put away our snowmobiles, the snow on the driveway is gone if not everywhere. We take the batteries out so they do not run. Our smaller sled has a studded track that tears up the trailer.
This sled is around 700 lbs, but must of the weight is in front. Standard forks were not quite long enough to pick it up. Bought some extensions which make the job easy.
Tractor is an L3200 with filled rears and a roughly 700# ballast box.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
Heavy Duty Excavator Ripper (New/Unused) To Fit CAT320 (A59225)
Heavy Duty...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2014 Chevrolet Equinox AWD SUV (A56859)
2014 Chevrolet...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
