What do you do with your forks?
   / What do you do with your forks? #221
My pallet forks are my MOST used tool, that goes on my loader......
Pulling boulders out of hay fields,
geeeeeeze, I could go on and on and on! lol
SR
Hey Sawyer Rob,
It looks like that "thumb" or grapple also does a lot for you, and looks like something we could use-may I ask where you did you pick it up?
Thanks,
Thomas
   / What do you do with your forks? #222
From my ALO loader dealer...
The forks/grapple are designed to go together and a REALLY GOOD design they are!
I use them all the time, it's amazing what all can be done with a "properly designed" set up!
SR
   / What do you do with your forks? #223
I use my forks for moving pallets, and rocks and stumps that don't fit it the grapple. I am also guilty of using then as a "man lift". Sometimes after the Kubota gives up I have to resort to a real fork lift.
   / What do you do with your forks? #224
SR
Thanks for the info, although it will likely be a while before I can use it.
Nice pictures too!
Thanks,
Thomas
   / What do you do with your forks? #226
There are several add on grapples for forks:
Hi XFaxMan,
Seems like almost any grapple fork combo would work well together, but my current problem is the lack of $ and of an extra hydraulic loop for their power source, barring using the curl function for both.
Thomas
   / What do you do with your forks? #227
Hi XFaxMan,
Thomas
Just for reference, I did a diverter setup for about $300. Pretty good, I think.
   / What do you do with your forks? #228
Hi XFaxMan, Seems like almost any grapple fork combo would work well together,
Thomas
Apparently NOT, the way some folks on this forum think you need a heavy multi arm grapple, to get anything done...
SR
Case Titan 3530 (A56435)
Case Titan 3530...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
1087 (A58374)
1087 (A58374)
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
PALLET OF FLUORESCENT LIGHT BULBS (A58374)
PALLET OF...
