What do you do with your forks?
   / What do you do with your forks? #221
My pallet forks are my MOST used tool, that goes on my loader......
Pulling boulders out of hay fields,
geeeeeeze, I could go on and on and on! lol
SR
Hey Sawyer Rob,
It looks like that "thumb" or grapple also does a lot for you, and looks like something we could use-may I ask where you did you pick it up?
Thanks,
Thomas
   / What do you do with your forks? #222
From my ALO loader dealer...
The forks/grapple are designed to go together and a REALLY GOOD design they are!
I use them all the time, it's amazing what all can be done with a "properly designed" set up!
SR
   / What do you do with your forks? #223
I use my forks for moving pallets, and rocks and stumps that don't fit it the grapple. I am also guilty of using then as a "man lift". Sometimes after the Kubota gives up I have to resort to a real fork lift.
   / What do you do with your forks? #224
SR
Thanks for the info, although it will likely be a while before I can use it.
Nice pictures too!
Thanks,
Thomas
   / What do you do with your forks? #226
There are several add on grapples for forks:
Hi XFaxMan,
Seems like almost any grapple fork combo would work well together, but my current problem is the lack of $ and of an extra hydraulic loop for their power source, barring using the curl function for both.
Thomas
   / What do you do with your forks? #227
Hi XFaxMan,
Thomas
Just for reference, I did a diverter setup for about $300. Pretty good, I think.
   / What do you do with your forks? #228
Hi XFaxMan, Seems like almost any grapple fork combo would work well together,
Thomas
Apparently NOT, the way some folks on this forum think you need a heavy multi arm grapple, to get anything done...
SR
2017 Jacobsen Greens King IV Plus Reel Commercial Mower (A56857)
2017 Jacobsen...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2018 Ford F-550 4x4 Terex LT40 40ft. Bucket Truck (A56858)
2018 Ford F-550...
403 (A52706)
403 (A52706)
CHAINSAW BENCH GRINDER (A58374)
CHAINSAW BENCH...
