what do these symptoms tell me?
   / what do these symptoms tell me? #11
Worn pump ......also bad shaft seal is sucking in air allowing it to lose prime when off
Bad shift seal on the pump? Or a ram?
   / what do these symptoms tell me? #14
Before you dismantle anything, take the tractor to a hyd shop for a flow and pressure test.
Or, pull the pump and take it to a hyd shop for testing.
You could do it your self if you had a 15 GPM flow meter, 3000 psi pressure gage, needle valve and relief valve.
You might ask wdchyd to post his video of the flow test.
Toro Mower (A50324)
Toro Mower (A50324)
(49) 2" X 3" X 27" TUBING (A54756)
(49) 2" X 3" X 27"...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
1999 Talbert T30W-50SA-HRG-1-T1 (A47477)
1999 Talbert...
