what do these symptoms tell me?
   / what do these symptoms tell me? #11
Worn pump ......also bad shaft seal is sucking in air allowing it to lose prime when off
Bad shift seal on the pump? Or a ram?
   / what do these symptoms tell me? #14
Before you dismantle anything, take the tractor to a hyd shop for a flow and pressure test.
Or, pull the pump and take it to a hyd shop for testing.
You could do it your self if you had a 15 GPM flow meter, 3000 psi pressure gage, needle valve and relief valve.
You might ask wdchyd to post his video of the flow test.
1987 International S1900 Flat Bed Truck (RUNS)(TITLE) (A50775)
1987 International...
2024 Frontier FL1061S Hydraulic Flail Mower (A55302)
2024 Frontier...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2008 GMC C5500 Dump Truck (A55788)
2008 GMC C5500...
UNUSED XSTAR 250 GALLON FUEL TANK (A54756)
UNUSED XSTAR 250...
Skid Hydraulic Hoses (A50775)
Skid Hydraulic...
