what do these symptoms tell me?
   / what do these symptoms tell me? #11
Worn pump ......also bad shaft seal is sucking in air allowing it to lose prime when off
Bad shift seal on the pump? Or a ram?
   / what do these symptoms tell me? #14
Before you dismantle anything, take the tractor to a hyd shop for a flow and pressure test.
Or, pull the pump and take it to a hyd shop for testing.
You could do it your self if you had a 15 GPM flow meter, 3000 psi pressure gage, needle valve and relief valve.
You might ask wdchyd to post his video of the flow test.
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2014 Ford Expedition (A55853)
2014 Ford...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
STRICKLAND CASE 621D WHEEL LOADER FORKS (A52705)
STRICKLAND CASE...
