what do i need.
   / what do i need. #1
shancooper
I'm sure you fellows can give me some advice. I recently built a house on three acres of land. I've always cut grass with a push mower. But now I'm going to have to have something. Problem is I dont know what I need. The land is hilly in front with three ditches and out back it flattens out to a kudzu patch. I borrowed a husquvarna garden tractor but it got stuck in the ditches and spun on the hills. I was also afraid of turning it over. So I have the go ahead and get what I need.
so I decided to buy a kubota bx. then I decided to buy a used tractor and a zero-turn mower. Because everyone says that with a big yard get a zero turn, but Im not sure it would be any better than the borrowed mower. I also looked at a john deere x5 hundred and something- it had a locking differential, maybe thats all i need. but now im back to the kubota cause it has a three point hitch, maybe i should get a bushhog for the kudzu.
Help me out, its a lot of money, but I don't want to spend my weekends regretting my decision.
   / what do i need. #2
4wd will come in handy for the hills.
Years to come you may want to re shape the land...garden...driveway maint. etc. and the 3pt hitch will come in handy for different attachments.
   / what do i need. #3
Zero turns are faster mowing than a tractor by a bunch. If mowing is all you are going to do the zero turn is the way to go. If you want to do other things the BX would be a better choice. With 4WD they are hard to get stuck. You can do so much more with a BX than a zero turn. There's always much more to do than just mowing the grass.
   / what do i need.
But will I be able to cut grass on the hills with a zero turn? I read that that may be a problem. And how effective is a locking differential on a garden tractor?
   / what do i need. #5
The BX is the better option of those mentioned. ZTR's are good except on steep/rough terrain, and all than can do is mow. An in between option might be a tractor with all wheel steer (AWS). Deere makes some new one's. Or consider a more affordable used JD 425 or 455 with AWS. They will mow any slope that is mowable and something comparable new is the x700 series, which costs some big bucks. My uncle has a X500. He says it's not the tractor that my 425 is, and actually prefers his hold cub cadet the x500.
But, if you have wide open spaces, the BX is hard to beat and bit more tractor, whick will lend itself to more tasks down the road. In this class/price range, there are other manufacturers to consider as well: JD, MF, New Holland, CC, TYM T233/T273 (killer tractor). Either way, used will save you considerable money.
   / what do i need. #6
I have never owned a zero turn. I have seen many a zero turn stuck in ditches driving to work. Commercial mowers use them. The places that these zero turns were stuck I could idle through with my 2WD Gravely riding tractor. If getting stuck is a concern for sure a zero turn is not the way to go.
   / what do i need. #7
zero turns do not like slopes.
the TYM 233 or 273 are great little machines, as is the kubota BX, but they cost a LOT less than that orange paint. Even so, a new 273 with loader will run you close to $12k, and the belly mower a chunk more. There's also the 15 series from Mahindra, which is another brand that sells good sub compact machines. Each of these can be purchased with loader (very handy) and all come with a cat 0 or cat 1 3 pt hitch, for which there are an abundance of attachments you can use to do a wide range of chores as the list grows over the years. (brush hog, tiller, rear blade, box blade, post hole digger, etc...)
on the flip side, a GOOD lawn tractor can be purchased that will not have a 3 pt hitch, but can still run a tiller, front grader blade, etc... for about half the cost of one of the above tractors - it just won't have the potential to be as versatile.
   / what do i need. #8
I bought a BX2350 about a year ago. Best tool I ever bought. For 10 years I used riding mowers and it was a constant battle. I got stuck, slipped on the hills, and they wore out quickly. Like others have said, there is alot you can do with a BX, plus it makes a great mower. I have turf tires, which aren't very good in the mud, but I still have yet to get it stuck, and I've tried pretty hard a couple of times. Plus they have a roll bar(ROPS) and seat belt, which adds to the saftey factor. The downside is the cost, there aren't cheap. They are pretty common used.
   / what do i need. #9
I've seen ztr's slip and spin bad on hills and gullies..
soundguy
   / what do i need. #10
zero turns save the most time where there are a lot of trees/bushes etc. to mow around...
steeper hills and ditch slopes are best mowed with 2 stroke machines to ensure proper lubrication...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
