What disc plough width ?
/ What disc plough width ? #1
mboncalo
not yet
Hi,
I am looking to buy a 5 disc plough and I saw I have 2 options regarding the ploughing width: 1250mm and 1500mm.
Which I should get and why ?
120hp tractor
Thank you.
/ What disc plough width ? #3
Hi,
120hp tractor
Thank you.
If you have good adhesion with loaded tires and R-1 tires the 1,500 Millimeter plow(4.92 feet)
will be fine as you can cut deeply to break up the ground to break up the hardpan and the compaction.
/ What disc plough width ? #4
With good traction (weight too). 120hp should pull 3000 millimeters (two Corollas).
/ What disc plough width ? #6
Not familiar with disk plows but conventional mold board we used to figure 20 HP per 16” (400 mm) bottom in sod. This was two wheel drive tractors with R1 ag tires.
/ What disc plough width ? #7
I was assuming he was referring to something like this.
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
Case JX75 (A64126)
Case JX75 (A64126)
1996 International 4700 (A64126)
1996 International...
2017 Mack Semi (A64047)
2017 Mack Semi...
2001 John Deere 6210 (A60462)
2001 John Deere...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
