What disc plough width ?
/ What disc plough width ? #1
mboncalo
not yet
Hi,
I am looking to buy a 5 disc plough and I saw I have 2 options regarding the ploughing width: 1250mm and 1500mm.
Which I should get and why ?
120hp tractor
Thank you.
/ What disc plough width ? #3
Hi,
120hp tractor
Thank you.
If you have good adhesion with loaded tires and R-1 tires the 1,500 Millimeter plow(4.92 feet)
will be fine as you can cut deeply to break up the ground to break up the hardpan and the compaction.
/ What disc plough width ? #4
With good traction (weight too). 120hp should pull 3000 millimeters (two Corollas).
/ What disc plough width ? #6
Not familiar with disk plows but conventional mold board we used to figure 20 HP per 16” (400 mm) bottom in sod. This was two wheel drive tractors with R1 ag tires.
/ What disc plough width ? #7
I was assuming he was referring to something like this.
PORTA POTTY (A67714)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
MAXEY PORTAPOTTY VAC TRAILER (A67714)
MAXEY PORTAPOTTY...
2016 Ford F-750 (A64911)
2016 Ford F-750...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
2017 PETERBILT 389 FITZGERALD GLIDER VOLUMETRIC MIXER (A67714)
2017 PETERBILT 389...
