What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #751
I'm trying something a little different here. Please let me know if you can see the image below.
SNY2PUgP3bAZCDNX6HRw6OfYWNhP1vC3SazoIQgYvu_AyQ5Vk6fspaFZCIeICwOVYt5PfrqOVW1azmo623HBzLFYgfuaCWRVn4vqF5AkALmqTSlNPBx838WoJxPQar6NMC03kUhJVyRbrO8DonjtOsyePn7NZZDo-Lu2SZd7XkkzBVHOSI5CU1mBHtFdYBZfcmFeDrwnZCSzV4RpAZfD8nztscLHwrF0Xw64q24DLvgdkakLtDyv9nAZ_PPCPx6QbwQ551iGpPXlXGmYQVecmI17c4xwZo7KHVMmaWhin4huyRX8E6qwHaJ1NYer6OIxVSHiSS3Lebd6cRsl0sASxb9PWBDDqFMWBoJwWdGDMKT1QK1DZvLaNBTdOOFv1t1oZdl1cby-TCGz6OZs81bCdPBitAzbIcs8JRgPwA5Zac2RMpwiR86W4Bj9YrhbeA6lwQvyQ7SVaXv-3c8Tdhp70QeXxpZEV0GXX2gyb7jXQVHvdxUlYChkM_LEn-ceIXdhXzW80jpJHDRuTrIWZAQzZp-E5wB8FM4MF_MErFPy_huwjM8u8qYKa-zRmLHb-dMqUfNceihFhC6IPciDVgyPOcejBrEScumRM_TDPU3WRVmuJi38M04ngDz6iQxDo6T690tsQ2PUCZ7vHhxoHBphBQzAKdGmZh6j=w903-h677-no
Think you are having a bad hair day?
If you can not see the image, view it here: Shared album - Google Photos
   / What did you do to or on your Mahindra today? #753
9ACA2FB9-364C-49A7-B8C3-D062D928D903.jpegUsed the tractor to help save my back cutting up firewood.
   / What did you do to or on your Mahindra today? #754
That moment when you get the thing home and ponder how youæ±*e gonna ask the wife to help..... then you remember you have this new tool that can lift stuff :)
   / What did you do to or on your Mahindra today? #755
Just moving some wood.
   / What did you do to or on your Mahindra today? #756
Finished a 480ft drainage ditch yesterday!
   / What did you do to or on your Mahindra today? #757
Here's a mod I did to keep my radiator from clogging on my older 4025. I cleaned the frame with electrical cleaner, and applied velcro, then put the filter material in front. When it gets dirty I can just shake it off. 20190902_155459.jpeg20190902_160412.jpeg20190902_160507.jpeg20190902_160737.jpeg
   / What did you do to or on your Mahindra today? #758
I didn't do anything on my Mahindra today. Now yesterday, that was a different story. I decided drop the Shanks on my box blade and use as a Chisel plow and find every stump at the property we have leased for hunting. Planting food plots.
I guess the timber company came in with a machine that cut the trees down even with the ground. I could not see them but I sure could feel them. Stalled my tractor more than once. Lost one shank off my box blade, bent the other 4. Found some on ebay for about $150 for 5 with pins and clips.
I got to get a disc!!!
   / What did you do to or on your Mahindra today? #759
Getting my 3616 back in good working order. Using what I learned from an old thread, I fixed my 3616 diff lock this afternoon. Earlier in the long weekend I replaced burned up glow plugs and added the diode / light to prevent them from burning out early again. Located stabilizer chains at TSC to replace the lame factory bars and will install those next weekend. Planning to load rear tires after that.
   / What did you do to or on your Mahindra today? #760
Replaced the OEM stabilizer bars with TSC SKU 265113. I just needed the turnbuckle and the two chain links that are pinned on. Did not need any of the chain itself. I think that this will work better and stop the stabilizer failures since it is not rigid in compression.
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
John Deere 772-A Grader (A52384)
John Deere 772-A...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
1266 (A50490)
1266 (A50490)
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
