What did you buy this week?
/ What did you buy this week? #3,381
I ordered from Ace and wanted it in the crate, so I could assemble it. I did speak to I&O on Thursday and though they don’t recommend the type of grease (just grease), the tech rep agreed that I could use white lithium, it’s just nlgi #2 grade. I have approximately 10 tubes of Rotella HD that I could have safely used. Should be alright for a while anyway. When I am out, it will be Rotella.
/ What did you buy this week? #3,385
Supporting local small town businesses up north, Bought my stepson a new pair of rocky brand winter boots (merry Xmas ) after he apparently thought his crocs would be sufficient for up north snowmobiling and other winter activities. Still shaking my head in disbelief at the his one. But I brought warm socks was his response 😂.
/ What did you buy this week? #3,387
lol. Might want to show him this chart. It’s labeled for motorcycles but applies to snowmobiles as well. Warm gear is a must.
/ What did you buy this week? #3,388
What I got off that chart is you can not cool down going faster once it hits 90F and after hundred there is a positive windchill.....
/ What did you buy this week? #3,389
Factor in 10 degree temps up here.
/ What did you buy this week? #3,390
I suppose whoever made the chart needs some education. Wind will never make the temperature feel warmer, even if you're on a motorcycle.
The chart also assume the only 'wind' is coming from the speed of the bike.
Another fun 'wind chill' fact...if the actual temp is above freezing, no amount of wind will make your pipes freeze.
/ What did you buy this week? #3,391
You have not driven across the desert at 115º with the winds down? (pre AC in every car)
/ What did you buy this week? #3,392
False. I lived in Vegas for 8 years and was too cheap to run the A/C.
Physics is a thing.
/ What did you buy this week? #3,394
Had a fan on the dash in a non-A/C car of mine, and it felt worse with it on when it was hot.
No A/C meant you were pushing the air heated by the engine into your cabin. The engine temp was much greater than 100 or even 115.
When I moved to Vegas, my little 200SX was so loaded down (thanks mom) that from about SLC to Vegas, I couldn't run the A/C. In fact, I had to run the heater to help cool the engine. Windows down, engine heat pushing into the cabin. Miserable drive. (Except the stretch through the Virgin River Gorge).
/ What did you buy this week? #3,395
Seems to me, it's all about body temp. If it's hotter than your body, I would think the wind would be adding heat to your body, just like if it's cold, the wind will carry the heat of your body away faster.
/ What did you buy this week? #3,397
The heat would add heat to your body. The wind helps your body dissipate heat. Part of the reason we sweat is our body's evaporative cooling. It is most difficult on a still, humid day as the sweat cannot evaporate well. Wind is essentially the movement of air from areas of high pressure to areas of low pressure. That wind also reduces humidity. Less humidity allows your body to cool itself by evaporating the sweat.
That is why at higher temps, they talk about heat index, which is more about the humidity. It's very difficult to have high humidity and high winds...usually only happens in a violent storm and in that case, the temps wouldn't remain high. Between rain being cooler, you get heat transfer, plus the clouds filters more solar energy from getting to the ground warming the air.
The planet is really a very interesting, self-regulating system.
/ What did you buy this week? #3,398
That's the thing about "wind chill" ... It's the wind causing the moisture in your skin to evaporate which "cools it" ... Can't happen on a normal engine block for example. (Or sitting in a closed up car)
When I lived in SE Arizona evaporative coolers (swamp coolers) were widely used, simply a fan blowing arid air over a screen drizzled with water that looked kinda like a furnace filter, the evaporation had a cooling effect on the air blown through the HVAC system, they also had "misters" that people would use on a covered deck or barn, they sprayed out a very fine mist of water, as it evaporated it cooled the immediate area ...
/ What did you buy this week? #3,400
I bought a small, portable table saw. I had a nice Sears contractor table saw for 40+ years. I hardly used it in the past 15 years, so I loaned it to my daughter and son in-law. Of course, I then had several projects that needed a table saw! 🙃
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
2022 FORD E350 BOX TRUCK (A59905)
2022 FORD E350 BOX...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
