What did you buy this week?
   / What did you buy this week? #2,642
Drip irrigation arrived today, for a small test plot of approx 200 evergreens. To combat new tree die off. Before I plant this fall, Most likely caused by lack of water. I shall see. Looking forward to learning something new. Insight and Tips by experienced irrigation folks is appreciated.
We put in 30 Norway spruce 12 years ago watered by hand, 4 years ago put in 40 more 5-6' size and installed 300' of 1/2" feeder line then the 1/4" drip line around each one with an orbit mechanical timer.
Some tips - pre-make all your 1/4" whips with like a 4' 1/4" feeder line - I did 24" circles (4 gal per tree in 60 minutes) then ran the 1/2" feeder line along the edge of all the trees then connect each whip to the main line and cover with mulch or dirt (I used my leaf compost).
It was about 10 minutes per tree to install, the most work was digging and burying the 1/2" feeder line. Very glad we put this in - so easy just to set the orbit timer for an hour and they all get watered evenly and easily.
   / What did you buy this week? #2,643
Not nearly as "intense" as many of you guys, but a few months ago I bought a used Miata with 43k miles on it. Discovered it has a GDI engine which means carbon will build up faster. So I bought a can of CRC Valve & Turbo cleaner ($17 for 11 oz) and used it to clean the carbon off of the intake valve. Could tell it was working because the exhaust smelled much different during the process.
   / What did you buy this week? #2,644
Miata is a great fun car. I've never owned one but I probably should have as I spent a lot of money owning all of it's competitors. Enjoy the drives.
   / What did you buy this week? #2,645
Picked the Titan 3 point gooseneck and 2 inch receiver hitch. I inadvertently got the one with suitcase weight holder. Gotta move the splitter and trailers about. Nothing heavy. Lets see how it works. Still in the box out front
   / What did you buy this week? #2,646
Bought a used damaged boat trailer. A huge fork lift unit set it on my trailer, and this is how I lifted it off once I got it home. Amazing the ideas you come up with at 2 in the morning. I used a set of chain falls on each end, and it worked great. The dog was in the house while this was happening.
   / What did you buy this week? #2,647
I certainly don’t consider myself an expert, but did just plant 60 trees with drip irrigation. It’s .9 gal/ft and I have it on a timer to run 4 hours every 3 days. I also added about 4” wood chips over the entire area. After 2 weeks they are looking healthier than when planted.
Pic from not quite completed.
   / What did you buy this week? #2,648
Motorcycle tire spoons and wheel spoke weights.
   / What did you buy this week? #2,650
Just placed an order for 1 apple tree (granny smith), 1 orange tree (a kimquat-mandarin cross), 4 blue berries (southern high bush), 2 black berries (thorneless), and an elder berry. Been sitting on a "house warming" gift card for like 11 months, and figured it time. We have had pretty good luck with blue berries through the years, but not so much fruit trees.
CASE TR340 SKID STEER (A52709)
CASE TR340 SKID...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
Toro Ground Master 4000D (A56857)
Toro Ground Master...
1990 LOAD KING BELLY DUMP (A58214)
1990 LOAD KING...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
flatbed trailer 24ft (A56857)
flatbed trailer...
