What ceiling height?
   / What ceiling height? #11
My walls are 12 feet and I think that's worked out to be a very good height. Ten would work, but would limit your door opening height to minimal levels. My door is 10 x 10 and it has also worked out well.
I find the height especially nice when working on wood projects. Standing a sheet of plywood on edge and/or long pieces of lumber are easy to manuver and work with. I have shelves all the way to the ceiling and still have open spaces on them. That's allot of storage!!!!
Another advantage to the taller walls is that you can always add a lean-to onto the sides of the building easier and bigger with taller walls. My lean-to goes out 12 feet with a 4:12 pitch and is still 8 feet tall at the ends. If I had a ten foot wall, I could have either cut my width down or had less height. Neither are options that I wanted.
Eddie
   / What ceiling height? #12
Eddie
Mornin Eddie,
My sentiments exactly !!! Im hoping to build my barn with the higher walls for woodshop considerations, and the other reason is so that I can have side lean-to extensions for implement storage and such... etc
Trust me guys, I'm a home builder and roof truss manufacture, and I know that the door will not be a problem. I'm going to have swinging doors that go all the way to the ceiling and roof trusses above that. The door will be 2 - 10' tall and 7' wide doors. There will be no header. The wall with the large door in it will not be load bearing. This isn't a pole barn, it will be a building built on top of the slab. 10' walls will equal a 10' ceiling. The only place clearance won't be 10' is where a light fixture is. It will have a gambrel roof with an upstairs. With the steep pitch, I could still add a lean to without a problem.
Now that that's out of the way, is there a reason to have it higher than 10' other than just because.
Here's a cad drawing of the front that I did.
   / What ceiling height? #14
Afternoon Dave,
Yeah !!! Really big tractors !!! ;) :) :D
   / What ceiling height? #15
A friend of mine had a good reason.......He bought his first pair of new shoes at the age of 18. He said he could wear 10's but 11's felt so good he buys 12's.
   / What ceiling height? #16
You will want a 10' tall door and if you go with an overhead you will want a 12' ceiling height. Also, depending on what you are doing a 16' wide door is great as you can pull wide implements in without any problems.
I just read the rest of the replys and I would still build it 12' tall even if you plan on building swinging doors. This way you will always have the option of the overhead in the future if you want it.
   / What ceiling height? #17
Unless you want to heat it, IMHO, go higher. My outbuilding is 16 foot to the trusses with half mezzanined. The end barn doors are fourteen feet high because the former owner wanted to be able to work on big machinery. The height gave me lots of options when I bought the place.
   / What ceiling height? #18
I built my 40 x 60 shop with 14 foot ceilings. I originally wanted 10 foot ceilings but was talked into 12 and ended up with a 14 foot ceiling. When drywalling the ceiling and walls I cursed the 14 foot ceilings because of the extra 2' strip of drywall and the extra taping it required. I also had to pay a small premium for the 14' drywall lift. That was a few years back and today I would not have it any other way. Like the others said go high. My mistake was only putting a 10 x 10 foot over head door. I really wish a had a 12 x 12 foot door.
   / What ceiling height? #19
You could lay 1 or 2 layers of cement block on top of the outside edge your slab, and then build the barn on top of your cement block. This would give you 10'8 (1 row of blocks) or 11'4 (2 rows of blocks). This will raise the barn off the ground too, which is a good thing, especially if it is wood.
   / What ceiling height? #20
DD 32" wide is pretty skinny any clearance reason not to go 40' wide? Makes your door 10x20 wide which allows 2 rows of entrance & egress leaving stuff along sides undisturbed.
Swinging doors work good until the snow piles up or the wind tears em up.
I have an old 14' class TLB that the boom can hit the door framing & trusses if I enter with it raised all the way. Once in, I drop both buckets so it takes up about 30 linear feet. The lawnmower (5' deck) winters under the boom.
Woodchipper & snowblower stand about 8' tall. 60hp cab ag tractor is about 102" at the muffler flapper.
10' also clears a class A Winnebago.
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
1041 (A50459)
1041 (A50459)
