What brand bar do you run?
   / What brand bar do you run? #11
Stihl lightweight bars here. Are they the best? I have no idea but they work great for me.
   / What brand bar do you run? #12
My Stihl bars of late don't seem to last as long as they did 10 years ago. Both rail and bar groove seem to last about half as long. Something has changed.
I'm sure. Just like the saws have changed. More plastic, higher price.
   / What brand bar do you run? #13
Don't get too concerned with rail wear. I flip my bars every time I switch loops and when I replace the loops (I run 2 loops per saw), I replace the bar, no exceptions. When I flip any bar I check the rails for wear and burrs and file them as needed. The trick if you will to mitigating bar wear is using a good bar oil and tensioning the chain properly. I keep my bar oilers on the plus side all the time.
I always flip and file after every chain gets dull. I like CAM2 bar oil and always run oilers at 3/4 or a little more depending on which saw. Tension is a bit variable depending on tightening in the woods or in the shop. Maybe I just expect too much from the bars. I saw on here where people are getting years of bar life and I just don't get that. I do cut about 10-12 cord of hardwoods a year but that goes pretty fast once piled up. Thanks !
   / What brand bar do you run? #14
   / What brand bar do you run? #15
I run Tsumura Lightweight bars. Long lasting for a decent price. Heard nothing but good things about Cannon bars, but they're crazy expensive for my tastes.
I'm running a .050 chain right now and have a few Sthil spares (24" bar). If the bar was longer I would look into going with .058 or even .063 but for 24 inches oiling shouldn't be a problem. I'm not hard on the tip but in the winter I do get lots of wear on the rails. I do sharpen the chain on the bar but usually remove it about every 6 tanks to make sure the groove and oil hole is clean. If needed I'll file the bar down. It seams like grit gets mixed in with the ice and when it becomes water and wears the bar. I can't complain as it's the original bar and probably has had several dozen chains over the years and it still has life left in so it'll be a backup. Right now I'm leaning towards a 24" Tsumura in .050". I don't see the advantage for me with going with a lightweight bar. I've never bent a bar in my life but it seams like I would days after putting on the saw, lol. I've never owned one so this seams like a good time to try one.
   / What brand bar do you run? #17
Stihl & Oregon
   / What brand bar do you run? #18
Oregon here and their round chisel chain too. As long as I do my part about keeping the groove clean, roller nose greased and oil running well they do not wallow out or wear down much.
prs
   / What brand bar do you run? #19
Cannon bars are pretty much aimed at the pro handfaller market.
   / What brand bar do you run? #20
Gotcha! Nothing pro about my work! I'm just a hack! I'll get by using my Tsumuras for what tree butchery I do! If I was looking to majorly upgrade anything, I'd spend my money to have the saw ported by a reputable saw builder before I'd spend big bucks on a bar. That's just my personal preference though, some of the "pros" you referenced might run ported saws already anyway. Cheers!
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
