careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,710
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
All it takes in ONE time and you have a flat head or worse. Like your picture of the boom pole with the weight box on the end. One dip or hole and she's going over and your 17 years comes to an abrupt end.Last time I looked, after 17 years of running this machine, my head was still intact.![]()
My tiller has shear pines and friction clutch.My garden tiller.
We don't know what is buried under our feet. Mechanically disturbing 6" of soil could get expensive.
For that reason, I quit tilling for hire.
They look more scary then they are but I almost put it in my list ... I still use one, I definitely tie up the dogs when I am using it.Modern Era. Post hole digger. Back in the day I never even wanted to be close to a Dearborn mower Attachment!
What brand/model is it? I've never seen one like that.My tiller has shear pines and friction clutch.
off hand I don't know but I thought they all did have slip clutch and shear pins or at least one or the other. The shear pins are on the tines shaft and the friction clutch is at the end of the PTO shaft... I will have to look at the brand and can come back to you in a week or so if it is still visible. But ya I have caught everything you can think of like tractor tire chains, shafts, rimes and stumps and never broke anything.What brand/model is it? I've never seen one like that.
I guess not obvious from that picture, but I don't run around with my weight box on the boom pole. I had just built the boom pole and was trying it out and doing a photo op.All it takes in ONE time and you have a flat head or worse. Like your picture of the boom pole with the weight box on the end. One dip or hole and she's going over and your 17 years comes to an abrupt end.
he his being dramatic... I think form now on every picture I take with my tractor I am taking my ROP down.I guess not obvious from that picture, but I don't run around with my weight box on the boom pole. I had just built the boom pole and was trying it out and doing a photo op.
I just thought that was kind of an interesting way to show the weight box. Did not expect it to start a controversy....
My Massey is the fist tractor I rode that had a ROP's... all the one prior was pre 1980 so didn't had one...With my M's folding the ROPS is NOT an option as the cab unit has it's ROPS built into the cab frame and my open station has a canopy attached to the ROPS so they are always 'deployed' and yes I wear a lap belt in the cab unit. The open station has no seatbelt. Never did.
Not really other than maybe my disc bine. I have to be careful with it because the rotating knives can cause small rocks to get ejected forward when mowing. Even my owners manual cautions about that and recommends mowing with an enclosed cab tractor instead of an open station.As far as the tread question, do you fine one of your implements more dangerous then others ?
Why keeping your fingers away from the knives when raising the cutter bar is the biggest operator issue.Modern Era. Post hole digger. Back in the day I never even wanted to be close to a Dearborn mower Attachment!
Worked for decades in Printing and Graphics. Printing press after 35 yrs.. Faulty sensor. Index finder ,Thumb and Wrist. didn't take them off but it was close! lucky that was all. Not really worried about me with the Dearborn but I could imagine all the poor Pochies and kitty's Etc. over the decades!Why keeping your fingers away from the knives when raising the cutter bar is the biggest operator issue.
Critters on the ground is a separate matter.
In reality the PTO shaft on any equipment warrants continuous respect.
