What are you using to lube your implements and tractors?
   / What are you using to lube your implements and tractors? #61
I use a bottle of implement lube.
   / What are you using to lube your implements and tractors? #62
I just want to know what 5030’s opinion is on WD40? Is it good stuff?;)
   / What are you using to lube your implements and tractors? #63
It is the duct tape of lubrication.
Sorry 5030, but since it is about 30% petroleum based oils, it is a lubricant. It does other stuff, too. Not the best overall lubricant, but a lubricant nonetheless. Like any tool, it is only as good as the person using it. Right tool, right job. I do agree it is not what I would reach for to lube a pto shaft, but nothing wrong with it if that is what you have.
   / What are you using to lube your implements and tractors? #64
I prefer the JD Polyuretha grease. I even use it for packing the wheel bearings on my trucks. Good stuff. I used to always use Redline grease which was also good, but I prefer the JD grease.
Me, I just want to know if it is a water dispersant? Can someone tell me that? Or, is it only good at lubricating?
   / What are you using to lube your implements and tractors? #66
It's a water dispersant first and foremost, hence the WD. Just don't expect long term protection.
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2005 PETERBILT 379 TANDEM AXLE SLEEPER (A56138)
2005 PETERBILT 379...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
KSI Conveyor (A55301)
