What are you using to lube your implements and tractors?
   / What are you using to lube your implements and tractors? #61
I use a bottle of implement lube.
   / What are you using to lube your implements and tractors? #62
I just want to know what 5030’s opinion is on WD40? Is it good stuff?;)
   / What are you using to lube your implements and tractors? #63
It is the duct tape of lubrication.
Sorry 5030, but since it is about 30% petroleum based oils, it is a lubricant. It does other stuff, too. Not the best overall lubricant, but a lubricant nonetheless. Like any tool, it is only as good as the person using it. Right tool, right job. I do agree it is not what I would reach for to lube a pto shaft, but nothing wrong with it if that is what you have.
   / What are you using to lube your implements and tractors? #64
I prefer the JD Polyuretha grease. I even use it for packing the wheel bearings on my trucks. Good stuff. I used to always use Redline grease which was also good, but I prefer the JD grease.
Me, I just want to know if it is a water dispersant? Can someone tell me that? Or, is it only good at lubricating?
   / What are you using to lube your implements and tractors? #66
It's a water dispersant first and foremost, hence the WD. Just don't expect long term protection.
New Three Point Hitch Trailer Mover (A54865)
New Three Point...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2006 Ingersoll Rand P185 Towable Air Compressor (A55851)
2006 Ingersoll...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
1994 International F-8100 Roll Off Truck, VIN # 1HTHCAUR7RH595438 (A54865)
1994 International...
