What are you using to lube your implements and tractors?
   / What are you using to lube your implements and tractors? #61
I use a bottle of implement lube.
   / What are you using to lube your implements and tractors? #62
I just want to know what 5030’s opinion is on WD40? Is it good stuff?;)
   / What are you using to lube your implements and tractors? #63
It is the duct tape of lubrication.
Sorry 5030, but since it is about 30% petroleum based oils, it is a lubricant. It does other stuff, too. Not the best overall lubricant, but a lubricant nonetheless. Like any tool, it is only as good as the person using it. Right tool, right job. I do agree it is not what I would reach for to lube a pto shaft, but nothing wrong with it if that is what you have.
   / What are you using to lube your implements and tractors? #64
I prefer the JD Polyuretha grease. I even use it for packing the wheel bearings on my trucks. Good stuff. I used to always use Redline grease which was also good, but I prefer the JD grease.
Me, I just want to know if it is a water dispersant? Can someone tell me that? Or, is it only good at lubricating?
   / What are you using to lube your implements and tractors? #66
It's a water dispersant first and foremost, hence the WD. Just don't expect long term protection.
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55302)
NEW HOLLAND 706 30...
1969 Jeep 4x4 (A54865)
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
