What are you using to lube your implements and tractors?
   / What are you using to lube your implements and tractors? #61
I use a bottle of implement lube.
   / What are you using to lube your implements and tractors? #62
I just want to know what 5030’s opinion is on WD40? Is it good stuff?;)
   / What are you using to lube your implements and tractors? #63
It is the duct tape of lubrication.
Sorry 5030, but since it is about 30% petroleum based oils, it is a lubricant. It does other stuff, too. Not the best overall lubricant, but a lubricant nonetheless. Like any tool, it is only as good as the person using it. Right tool, right job. I do agree it is not what I would reach for to lube a pto shaft, but nothing wrong with it if that is what you have.
   / What are you using to lube your implements and tractors? #64
I prefer the JD Polyuretha grease. I even use it for packing the wheel bearings on my trucks. Good stuff. I used to always use Redline grease which was also good, but I prefer the JD grease.
Me, I just want to know if it is a water dispersant? Can someone tell me that? Or, is it only good at lubricating?
   / What are you using to lube your implements and tractors? #66
It's a water dispersant first and foremost, hence the WD. Just don't expect long term protection.
TRUCK PARTS (UPSTAIRS) (A55745)
TRUCK PARTS...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2000 Ford F-650 Truck, VIN # 3FDNF6541YMA65799 (A54865)
2000 Ford F-650...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A56129)
2022 MACK GRANITE...
